goodvibes
- Dec 28, 2009
Did you try by-pass the caps, just short circuit? If there is no shift on base voltage, it will be good.
OMG, they aren't coupling caps. Boom, snap, pop!
Just a newbie here... Wondering if anyone can explain in simple terms how the PMEQ management works.How do the Filters work and what exactly are the FO, LSF/BPF/HSF and Q. How do we know what to calibrate in order to get the desired effect? It is so much simpler with manual equalizers and levers.
Thanks in advance.
There is a link on post 2 that explains how the PMEQ works with graphics. Check it out.
Yeah... I have seen that link. Unfortunately, the information is in Chinese and I would really to know the intricacies of how the PMEQ works. But, thanks for pointing out the link.
LME49600 is very addictive.
See if you can get a hold of ak380, I am so tempted.
Never heard of them before,please report back if they are any good.If I see it, I'll try it. Right now I'm waiting on the Flare Audio R2PRO. I'm hoping that's a good isolating pairing with the Paw Gold.
I audiotionned the Ak380 and the PG side by side. People will tell you the 380 is a departure from the AK sound which is true but then again not. It sounds close to the AK240SS, maybe a little wider and more airy, with a slightly more natural tone. But both are very different from the PG, which has more power, more depth, more raw feeling, but maybe a bit less width and clarity. I am not an expert but PG is very different from AK380. And now I want both, but since I have the 240SS, maybe I crave the PG more.See if you can get a hold of ak380, I am so tempted.
