Did you try any spiral dots? I have some coming in from Japan. Should be here by Monday
Not yet, but they don't have as wide a stem as the CL2 bore from what I can see, contrary to the Tennmak.
Hey guys,I am just going to get straight to the point, I have been following this thread since it started so I wanted to ask how does it fair between something like the andromeda, vega or ie800, where does it fit between those iems and is it worth buying, btw my first ever iem I have ever bought was from rha because of its good build quality , and also a more detailed description of the sound signature.
I haven't heard Andromeda, but I have owned for a long time (almost two years) both Vega and IE800, as well as IE800S.
Both Vega and IE800 have more bass presence than the CL2, mainly because the CL2 has « cleaner » bass with no mid bass boost. This being said the CL2 has great bass kick and it probably extend lower or anyway has more control and detailed bass with more texture. I don’t see the CL2 as a basshead IEM (from the sources I have used so far, YMMV), but as a neutral detailed IEM with a lot of energy both down low, in the mids (thanks to the upper mids) and up top.
There are commonalities with IE800. They both have very energetic signatures (this is much less the case with IE800S), but contrary to IE800 there is no harshness and no treble peak on the CL2. Soundstage is very similar, wide but the CL2 is airier and imaging is more precise. They both feature great clarity and transparency. The CL2 is more natural sounding although I think the IE800 has better timbre but let’s see how it evolves as the CL2 burns in and also how it does with other cables. I think if you liked IE800 you’ll like the CL2 as it basically is a more mature tuning of the same philosophy of exciting tuning. The only thing right now I would say IE800 has the edge is the mids, but that’s for my taste as I prefer warmer mids. The CL2 mids are quite neutral and accurate.
The Vega is nothing like the CL2. It doesn’t care about being neutral although the mids are fairly accurate. But its massive bass presence is overwhelming and it needs a good source to have some kind of control over that huge power. There is much more mid bass than CL2. The highs can be harsh at times although not as hot as IE800 famous peak.
Last but not least CL2 is fast, very fast all across the range this makes for great PRaT. The CL2 has a great sense of rhythm.
It’s speedier than both IE800 and Vega and by a big margin, more akin to top balanced armature IEMs.
