NickyNose
This is the review that convinced me to buy it.
this guy is awesome, he is also on headfi.
Thanks for this.
You both convinced me, I just ordered it and a 4.4mm pentacon.
Looks like I can only enjoy CL2 with balanced out when using portable DAPs. SE simply cannot drive CL2 properly, the lows/mids are very muddy, veiled. KANN can drive CL2 with balanced out but not to its potential. Either CL2 is very hard to drive or I am spoiled by WA8! You can get loud enough volume but dynamics are lacking. Sigh....I thought I found a good on the go IEM. I think I still need to get a U18.
lmao. You are definitely spoiled by the WA8. (Makes me wanna try them)Looks like I can only enjoy CL2 with balanced out when using portable DAPs. SE simply cannot drive CL2 properly, the lows/mids are very muddy, veiled. KANN can drive CL2 with balanced out but not to its potential. Either CL2 is very hard to drive or I am spoiled by WA8! You can get loud enough volume but dynamics are lacking. Sigh....I thought I found a good on the go IEM. I think I still need to get a U18.
Maybe I missed something but the CL2's are only 15 ohms. Seems pretty easy to drive to me.
I tried Fiio Q5, you should not try it, it makes the sound even worse!!That being said, there's not a shortage of portable amps putting out more power than the WA8 at 15 ohms. If they sound good with the WA8, then one could make a portable stack with, e.g., an iFi xDSD, Fiio Q5, or Vorzuge Duo that would provide more power than the WA8 at that impedance while probably being no more or cumbersome than an AK Kann on its own. (Although the Kann, also, should have no problem driving the CL2s based on power requirements.)
Probably it's not the WA8's power output that's giving it the edge here. More likely it's sound coloration (yay tubes) or, I dunno, something about being class A.
Note: I haven't heard literally any of the things I just mentioned, apart from T50RPs : )
These still sound really good with my cowon plenue d 3.5mm end.Maybe I missed something but the CL2's are only 15 ohms. Seems pretty easy to drive to me.
Might be crazy...or just broke, lol. Give yourself some time to appreciate the equipment before buying more. Trust me, I've been down the path too many times myself.I might be crazy. I ordered the CL2 and I'd joined the drop for MxEE Zeus. I can't wait to see how it compare to m1060 and HE 400i. I also joined the drop earlier for xDuoo X3 II for $90. I hope it's good. Good music just make me happy.
A lot of people say that the SQ on dx150 is better than the DX200. And 4.4mm zx300 is considered better than both. The SE on ZX300 is worse than the DX150. ( ZX300 and DX150 are really close overall )CL2 with WA8 at low volume is losing dynamic until 2/10. Man, this IEM is hard to drive! When above 2/10, the bass becomes strong, thick, quick and powerful. Very satisfying. Still not as good as Andromeda but it is very close. I am thinking of buying a DX200 with AM8 so I can drive it when out. This thing is demanding...
