drm870
- Feb 17, 2012
Thought about getting soft canals for my currently-processing Westone ES5 reshell (as they had them to begin with), but ultimately decided against it.
Does InEarZ have the ability to change the earplug socket? I am not a fan of the dual pin.
Yes they do, but you might want to contact them directly about the type of socket. Sometimes they even let you send them your own, but confirm first.
Hey All!
The website has issues when viewed with Internet Explorer Browsers as already mentioned.
It works great with Chrome and Safari
Hope you like it
Can anyone advice if Inearz remolds maintain the same driver placement/positioning, as the original iem?
Thanks @tayano. I guess my question was due to potential benefits with the phase. For example, some IEM manufacturers purposely position the high frequency drivers further back so help with the phase.As I understand, they tune the sound so it will be as before remolding. This should be more important than the actual position of the drivers?
Stay tuned! Just received Inearz re-shelled UM Pro 50 (in a clear shell) which I'm going to compare to my original UM Pro 50. Out of the box they look really good! I appreciate that Inearz kept it down to a single bore opening, just like the original Westone, and also kept the original mmcx connector. The fitment is perfect, and the sound is great, but I need a few hours of burn in for everything to settle before jumping into any impressions. Also, since Inearz shell is clear and the original UM Pro 50 are frosted-clear, I will take more close up pictures so you can see the physical driver arrangement.
