I meant reshelling cost for IEM
Give them a call, they answer. The number is on the site.
I'm having a hard time viewing the page as there is no option to scroll left to right. I'm using Internet Explorer browser. I'm at work so I can't try any other browsers at the moment.
No issues with IE browser here, but you might want to use Ctrl + "-" or "+" to zoom in/out of the page so you can see it better.
Hey All!
The website has issues when viewed with Internet Explorer Browsers as already mentioned.
It works great with Chrome and Safari
Hope you like it
Would you guys recommend me get the "soft canals" or stick with the normal acrylic?
What do you mean by "soft canals", acrylic body and silicon nozzle, like in Westone ES60? Are you re-shelling IEM with Inearz? From my experience of acrylic IE-P650 and Ei.xx and "hybrid" ES60 - all acrylic is a little easier to insert in your ears, while with silicone nozzle if your ears are dry you can hurt yourself (need to lube it up). Unless if you meant something else by "soft canals"?
Soft canals is a $40 option Inearz offers.
but what do they mean by "soft canals"? You have silicone tube audio canals that go from BA drivers to the bore openings in the nozzle I think they probably meant the nozzle part which is made out of silicone instead of a whole solid acrylic shell, but I just wanted to confirm. With silicone nozzle you get a better seal, but i found it a little harder to insert in your ear (based on my experience with ES60).
