melkenshawn
- May 5, 2011
Inearz received my jh13s on 27/03
Shipped it out on 25/04
Let the waiting game begin...
Huh... Now I'm curious... I just want the sound to be as close to the original ES5 ad possible, but now I don't know whether the ES5 started off as a triple or dual bore... As I said, the ES5 I received was done by Variphone and was dual bore, and yes, one of the bores seemed larger than the other, though it's been out of my possession for a few days now, so I can't verify. Maybe we should ask around to see if other ES5 owners have a dual or triple bore setup? If its originally triple, I'll have to call Fisher tomorrow and request that it be changed to triple. I'm just not sure why Variphone would make them dual bore if they are originally triple bore per Westone's specs?
EDIT: After poking around for a bit, I have found evidence that supports the fact that the ES5 is in fact, a dual bore design. If you go to the ES5 product page over at Westone there is an icon that denotes that the ES5 features "dual bore technology". You can find that same symbol on their "technology" page. I now wonder what a triple bore design would do to the sound...
You're right. I just checked the Westone ES5 thread and it mentions the double bore. Weird! I could have sworn it had triple bores.
Does your IEM cause any part of your ear to feel "sore" after 40+ min. of use?
Mine does.. is it worth getting a refit over @ Fisher?
IMO, it's harder to get over the idea of sending them in. I think it's worth it to get it as perfect as possible. If it continues to bother you and you foresee it being an issue, better get it dealt with early than late. If its a seal problem, it may change as you play around with insertion technique and fit. Is it painful inside your ear or outside?
-edit- i think thats what watagump meant... cryptically haha.
Ugh I wish it would hurry up and be Friday, then Monday lol
Does anyone know if a audiologist generally charges for shaving the customs? I'm thinking maybe I should take my monitors to the audiologist I went to because I'm not really sure what is bothering me because it varies from time to time, if I push it in to complete the seal then my anthelix hurts but if I put it in where my anthelix does not hurt, I don't get a seal. It's really odd and I don't know what is the real problem, my guess would be that it's the anthelix part of the monitors that is causing all the problems but I'm not really certain.
