AlexRoma
- Apr 28, 2010
Hi david8090. For some days long, I have been browsing for the same topic you are frustrated with. I also ended chosing between :
HiFiMan RE262 ~ VSONIC GR07 ~ Brainwavz B2
Than I had founded these, that eliminated RE262 from my list :
I think you did enough research too, and you do already know the sound signature of all these offerings, but the thing bothering you is an direct A/B comparison between GR07 and B2, right ? Than here is it ! I Had found it :
Personaly, after had read this, and having already known that DBA-02 = Brainwavz B2 + extra sibilance, I've chosen GR07 !
At the heart of the RE262 is still an impressively clean and quick dynamic driver with plenty of headroom – more so due to the 150Ω impedance and low sensitivity. Indeed, the RE262 is a power-hungry beast of an IEM – and one that drains the battery in my much-abused Cowon J3 in less than 8 hours when running unamped. Though still very impressive right out of the J3, I do feel that the RE262 benefits from a dedicated amp, sounding tighter, cleaner, and bigger with added power (more on that later)
Source : Multi-IEM Review - 162 by Jocker
So, I am damn lazy and finally...it's time to update a little bit.
I was comparing GR07 and DBA-02 side by side. This after listening to more sibilant things like Hippo VB, S4 and Crossroads Woody 2.
With recordings which had vocal sibilance, I can say that GR07 fared a little better. It actually turned out to be a little softer in presenting sibilance compared to DBA-02. At first, DBA-02 was winning by a margin and then suddenly, 'it' happened. Now, I have to say it's a matter of choice.
Briefly....
GR07 sounds more spacious due to the size of the sound stage.
GR07's bass is 'substantial' when compared to DBA-02, though GR07 is miles away from bass-head levels. It's more filled, textured, extended. Suffice to say, wherever there's bass, GR07 would score higher points.
DBA-02's mids are forward and due to the faster driver can present much more details when it comes to fast music. It's also, let's say 'sweetly colored' and sounds more natural. Where GR07 scores and scores heavily over DBA-02 is the texture. The guitar solos sound sweeter on GR07 at times due to the weight and texture it adds to the instrument.
Compared to bass, the roles are reversed in the case of treble. GR07 does present all details, but does not have the sizzle as in the case of DBA-02. This also comes down to recordings. If the recording already had elevated levels of treble, you'd choose GR07 over DBA-02. But in all other cases, DBA-02's lean, fast, brilliant treble scores over GR07.
Since many of the albums I own have vocal sibilance, I cannot avoid it. I am going to just lower the volume a bit and carry out more comparisons against GR07.
Source : esanthosh's review
