Oct 17, 2019 at 12:51 PM Post #901 of 1,305
Even more choices !
I am using the black filters from the R1 and really love them .
regards
I’m using the gold Zenith filter on the Aten which is perfect for my everyday usage and being very genre versatile, plus it matches the gold grill.
With the Zenith I’m using the Aten black lower and gold upper for specific genre use of electronic music.
Oct 18, 2019 at 8:46 AM Post #902 of 1,305
I already have a problem with the Aten two weeks after the purchase.
A cable connector, on the L side, moves a lot and sometimes I lose the signal. I tried to reverse the connectors but I have the same problem. I therefore believe that this is a problem inside the left earpiece.
I only mounted them when they arrived and then, suddenly, I lost music on the left side.
I wrote to the IMR seller and I hope it solves the problem. I also hope this is an isolated case, so I would like to ask you if someone has had a similar problem.
Oct 18, 2019 at 8:52 AM Post #903 of 1,305
Didn't have this Problem with any of my 3 IMR IEM's and also never heard of a similar case.
Are you sure its not just an issue with the cable connectors? Is it visible at all, so you could provide some pictures?
Oct 18, 2019 at 9:14 AM Post #904 of 1,305
Meanwhile, Bob already answered and informed me that they will send me a replacement. Congratulations indeed to the rapid and effective assistance.
Back on the problem, I tried to reverse the cable connectors but the problem remains always and only on the left side.
I made a short video. As soon as I load it on Youtube I post the link.
Oct 18, 2019 at 1:45 PM Post #905 of 1,305
I once had the earpiece detach from the cable without having tugged on it, just like that, but that was with the R1 so with very different cables. The socket on the R2 is much more secure so there is a good chance the replacement will fix your problem. Also there have been no widespread reports of mechanical failures in this thread.
Oct 18, 2019 at 5:45 PM Post #906 of 1,305
I had a similar issue with the balanced cable, Bob sent me a new one immediately and it never occurred again.
Oct 19, 2019 at 1:38 AM Post #907 of 1,305
in my case it is not a cable. I think it's inside the headset. I sent the video to Bob, I hope it's clear.
Oct 21, 2019 at 3:07 AM Post #908 of 1,305
Oct 21, 2019 at 3:20 AM Post #909 of 1,305
I had the same problem with the Aten L earpiece at the third weak of usage. Contacted Bob and he advised me to open the faulty earpiece and to check connection. I opened and found that connection are ok , therefore some of the drivers is malfunctioning as only very weak sound was coming out. I sent my findings with a photo to Bob and he immediately sent me replacements. Greate service IMR!
Oct 28, 2019 at 11:24 AM Post #911 of 1,305
Hi guys, I've just published my full R2 Aten review here and on the Headonist. Enjoy!
Congratulations, nice review.
I agree almost on everything.
You were right to say that perhaps ... too many choices of filters create more confusion than advantages.
Oct 28, 2019 at 11:26 AM Post #912 of 1,305
MBob sat me the whole left earpiece, obviously without the filters.
Thanks to Bob for the fast and correct assistance.
Following this I took the opportunity that was proposed to me to order the RAH.
Oct 28, 2019 at 11:29 AM Post #913 of 1,305
Thank you, and yes, I think by offering too many choices (some of which seriously detract from the SQ and capabilities of the driver), it not only confuses but also takes away from the overall experience. Then again I've always found too many choices a distraction in my ultimate goal, which is to connect and enjoy my music in the best way possible. Constantly thinking about which filter and which nozzle to use with which album is the antithesis of this. Of course my point here is that even though Bob gives you all these options doesn't mean you're obliged to use them. I asked bob what his favourite combination was, and it was probably no coincidence that it was my preferred combination as well. I mean, he did make and tune this thing. The Aten is currently my daily driver, FWIW.
Oct 28, 2019 at 7:04 PM Post #914 of 1,305
And the winner is....?
