I have never seen so many hardened burn in sceptics have their minds changed through the experience of burning in their IMR IEM's. Its a genuine pleasure to see.
So many people like to fall back on a 'non-experience' intellectual view of burn in...'I haven't experienced it, therefore it doesn't exist'
Anyway, thought it would be interesting to share a part of some
documentation from Morrow cables - Its related to cables but there are some parallels
What you will hear:
With Morrow Audio cable products, we have found that the sound is good at first, then there is a dip in sound quality. This dip quickly rises back to a comfortable listening quality with a steady improvement, rising far above the first listen until the end of the break-in process. This whole process generally occurs over a 50 to 400 hour period, sometimes as long as 600 hours depending on the cable model.
In order to help you know what you will hear during this process, we have provided below an explanation and actual customer testimonials for the first hours, mid-way hours and then the sonic glory of a fully broken-in product.
The first 50 hours:
When you first hook up your cables, you will hear about 70% of the sonic potential the cables have to offer. The highs might tend to be a little peaky and/or harsh, bass may lack and the midrange "sterile". This will soon go away and the frequencies will even out as the break-in process advances. Note from the testimonials below that the “high frequencies” is the area most noted.
- "After receiving the new Morrow cables, I immediately began playing music on them. They sounded thin, no bass, but the highs were rather promising."
- "I could hear early on how good the clarity and definition were."
- "At first, they sound rather lean..."
- "The highs were flighty in the beginning, but the promise of something good was there, so I hung in there, and am
very, very pleased. Clean as a whistle."
Mid-way through the break-in process 50 to 100 hours:
Between 50 and 100 hours you will experience the "difficult stage" of the break-in process. The sonic potential of the cable drops to 50%. It may be difficult to listen during this time. This is when some of our customers make a pre-mature return, missing out on the full sonic glory of the product.
- "Well, two weeks later, (as described in the break-in paper), things got worse. I remember thinking to give them a little time before you send them back. It was almost a full week before they started to improve, but when they did, what magic!"
- "Things are starting to happen. I came down last evening to have a quick listen. I estimate that I was at the 55-60 hour point with the interconnects. The sound was flat and uninteresting; the sound-stage seemed to
have collapsed. Instruments that had been 'hard right' before were now somewhere in the center. I put the CD
back on repeat and left. This morning...what a difference...67-72 hours ...exactly as stated by your users. I am
going to China on business for about a week but will be ordering more cables when I return."
- "The highs can be a little peaky during the mid-hours of break-in. There is a dip in quality from what was heard
during the first hours. Bass and midrange appear to be a little thin."
- "The cable opened up tonight. What a difference a day makes. Dynamic, clear, full and weighty. It is a very
musical speaker cable and images very well. Was nasally yesterday and the day before for that matter."
A few 170-hour testimonials:
- "Changes? Absolutely! I must tell you that I was somewhat skeptical, not necessarily about the actual existence of a break-in process because I have experienced some of it with other cables. However, I must tell you that about 10 days ago, with around 170 hours of playing time on your interconnects, the sound changed dramatically! Even my wife noticed the changes. Both of us are very impressed with the changes that occurred.”
- “Suddenly, the soundstage opened up significantly, timbers became fleshier and more realistic; dynamics [micro and macro] are more organic, and articulations [staccatos, pizzicatos, etc.] are more natural. But the most dramatic change occurred with the sense of 'physical space perception', as I can best describe it. My wife nailed it: it sounds like live music now! This perception is more evident in our several recordings from the Mapleshade label, which has wonderful jazz recordings.”
- “Mike, I am a professional conductor, so I've been working with college choirs [and occasionally with orchestras as well] for a long time now, so I know a thing or two about musical sounds. I must say that your cables have definitely helped my stereo gear get closer to what real music is!"
After full break-in:
As you reach the end of the break-in process, the frequency extremes fill and smooth out, the midrange bloom returns
and the cable takes on a very natural sound presentation.
"I just wanted to let you know that after 336 hours, the MA3 interconnects are awesome in my system!!!!! Your 5- day burn-in helped a lot and then I ran them in another 96 hours.
WOW! Want you to know that your MA3 kicked major butt over the 4 times more expensive interconnects I was using. Now, I am a believer."
"After this break-in period (280 hours), I played disc after disc and became a believer in Morrow Audio's hype. The bass was spectacular, the highs were open and nicely extended, but the midrange with female vocals or acoustic instruments, like guitar and piano, became surreal. Whitney Houston and Karen Carpenter came to life. Recordings which were really good became great!"
"As the cables break-in, the bass and lower midrange fill out, and the cables become much more extended at the frequency extremes."
"Amazing clarity of sound and deep bass."
"Clear, precise, great rhythm, deep clear bass, inner detail..."
"They have great clarity, presence, extension and just sound beautiful! I believe these are quite special."
"The cables have a very natural sound and do an excellent job of preserving the natural timbre of instruments." "The sound stage is huge! I'm very happy."
"There is substantially more bass with no loss of clarity/ definition. The midrange/ highs sound very natural." "Great audio cables Mike! BIG improvement on my audio system... soundstage, focus, tone quality, it is all there."
