- May 5, 2010
Nobody knows.....they don't exist yet.
can the X3 support 128 GB of micro SDXC card?
I am listening to my X3 after 30 hours flat burn-in..but still I feel that E17 sounds better than X3. My Xperia S (with JB) has similar sound quality as X3
I started feeling that I wasted my money on X3
Does it need more burn-in? or is it picky towards IEMs? I'm using Brainwavz M2 IEM
If you haven't already, try adjusting the gain and adjust the treble / bass controls. I found those made a huge difference.
Many thanks for your reply ClieOS.
So as long as I transfer my individual music album folders into the Fiio's internal library, then I should get gapless functionality the same as I get on my Cowon i9?
The internal library, is that linked to the internal memory only, or will it work with with a 64GB Micro SD Card?
I'd hate to spend £200, including 64GB Micro SD Card, just for me to go backwards in functionality.
ClieOS, thought I'd pop into here for a quick question regarding a comparison.
Between the X3/C5 combo and the C3/C5 combo, which do you say is superior, and in which ways are they better?
Thanks.
You need to either manually update the internal library database or set the X3 to auto update itself (all in the setting menu). As long as the files are all indexed correctly and show up in the library under one album name (be sure the album artist and artist are all the same in the ID3tag), then gapless will be supported when you play the music via 'category > album > whatever album you want'.
The internal library is just a database to keep track of all the albums' metadata. It will work on both internal and external memory.
Both X3 and C3 are very clean when used as a source to another amp, but X3 does have a proper line-out and much higher dynamic range compared to C3's maxed headphone-out. X3 also handles a wider range of files type as well as 24/192 recoding. The larger screen is also easier to use, especially if you have a lot of files to browse through. Though C3 is smaller in size, it weights almost as much as X3 (127g vs. 135g), so there isn't any advantage there. The only aspect C3 is a way ahead of X3 will be on the battery life. X3 will run over 10 hours easily (could be as many as 15 hrs )when used as line-out source only but C3 will run much longer generally. The EQ system on X3 is hardware based and generally more useful (though a bit limited) and better behaved than the software EQ on C3.
So unless battery life is an concern, I'll say X3 is better overall.
Finally got a chance to test out the X3 it's pretty good! Love it's small size and its solid build quality. I've only used I products so I don't have other dap to compare it to but for the price I'm sure it stacks well against everything.
Well the tryout is over so if anyone is interested in the X3 I've put mine up for sale.
...........What? Why are you selling it?
Quote:Finally got a chance to test out the X3 it's pretty good! Love it's small size and its solid build quality. I've only used I products so I don't have other dap to compare it to but for the price I'm sure it stacks well against everything.
I've done all of this and I am still having issues with gapless playback. This is with lossless files, which if I'm not mistaken should not happen, as lossless files are supposed to be immune to gapless issues are they not? I know all of my files are properly tagged and yet when I go into categories/album all of the tracks of all of the albums I have loaded on the player are shown in one long list. I figured I had to wait for another firmware update as even James from FiiO says that they need a firmware update to correct the gapless playback issues.
.....lossless files are supposed to be immune to gapless issues are they not?...
None of my FLAC music are gapless.
