[Impression] Apple Nano 7G + Lightning-to-30pin adapter
Oct 31, 2015 at 11:40 PM Post #122 of 167
Does the line out work with the Oppo HA-2 Amp/DAC MFi cable? Oppo's website doesn't list the iPod Nano 7G. Also, will I notice a difference in sound quality if it does work?
Already confirmed that it will work on my HA-2 review, and of course the SQ improvement is very dramatic.
However, just to be technically correct - it isn't a line-out, but a digital-out with the MFi cable.
Nov 1, 2015 at 12:01 AM Post #123 of 167
That's great to hear. I was planning on getting the HA-2, so I just wanted to confirm. Thanks for the quick reply!
Digital-out.... okay, I see. Thanks for the correction.
Nov 1, 2015 at 8:44 PM Post #124 of 167
Any advice on what to get first...... DAP or DAC/AMP? Here are my options:
1) an Oppo HA-2 connected to an iPod Nano 7G
2) an iPod Touch 6G using headphone out (don't really care about the extra features.... just for music)
3) or a Fiio X5ii gen (only thing that's holding me back is the UI and if sound quality is significantly better than iPod Touch)
Nov 1, 2015 at 9:35 PM Post #125 of 167
Both one and three will be excellent sounding, but offer different features. Don't know about iPod Touch to comment about it.
Dec 31, 2015 at 8:19 AM Post #128 of 167
So when using the HO to a external amp, what recommendations would you suggest to set the 7G EQ to?
The same as to all of Apple's EQ - off.
Dec 31, 2015 at 2:27 PM Post #129 of 167
Currently running an iPod Nano 7g into a Pico Slim via a 3.5mm to 3.5mm, they really do fit perfectly together!
Sounds pretty good with my IEMS.
Jan 1, 2016 at 5:10 AM Post #131 of 167
  @ClieOS
Have you measured Nano 7G's output impedance? I'd be really interested to know it.
Yes, I had. It is mentioned on the first page review - a quite respectable 1.1ohm.
Jan 1, 2016 at 5:21 AM Post #132 of 167
@ClieOS
Whoops, somehow missed that, sorry.
1.1, that's surprisingly good and the best measured value out of all iPod Nano generations.
Jan 16, 2016 at 7:02 AM Post #134 of 167
I have a question can I use a external dac with the apple ipod nano 7g? Such as a fiio eo7k or q1 with the apple lightning usb adapter and mini usb?
For your first question: Yes, you can use an external DAC for Apple nano 7G, but it only limits to DAC that are officially MFi certified for iPod.
For you 2nd question: No, reason as stated above.
Jan 18, 2016 at 12:45 AM Post #135 of 167
I need to get cables / adapters to connect my gen 7 iPod Nano (line out) to the RCA input of either the Vali 2 or Project Starlight / Sunrise amp. I tried this setup using headphone out into the amp and found I lost detail. The iPod had more detail w/o the amp in this configuration so folks suggested the line out method into the amp.
It looks like I need to go from iPod Nano > Apple OEM Lightning to female 30 pin converter (w/built in DAC) > male 30 pin to 3.5mm male (or female?) end > 3.5mm female to L/R male RCA's into amp?
It would be nice to have 1 or 2 less cables to do this line out from the iPod into the amp............ and perhaps there are!
Any suggestions or pointing me in the right direction would be appreciated.
