dogpound5
- Jan 7, 2008
If you have or can borrow a multimeter you can probably figure out where the break is on your oem cable. Most likely at a joint. So just re-solder.
Maybe you can re-cable with some quality wire and a new plug?
I have absolutely no experience with selection of wire and plugs. Maybe someone here can point you in the right direction.
Quick search on ebay shows some silver plated copper teflon. Do not know if this would be appropriate and what gauge you will need.
eBay Store - John's Silver Teflon Wire Shop: Silver Teflon Wire:
Here is the DIY Gallery. Someone used cat6 network cable to splice.
http://www.head-fi.org/forums/f6/diy...8/index20.html
I haven't heard any of the etys so maybe you could ask someone who owns both. Just for refrence according to headroom:
er4p: 27ohm
er4s: 100ohm
er6i: 16ohm
Do not know how the above numbers compare with the 716s. Maybe it's just efficiency.
Good luck.
Originally Posted by Gino /img/forum/go_quote.gif I envy you. My oem cable broke and I replaced them with Apple oem cable. It doesn't have the same bass. How much do new ones cost now and where did you order them? |
Originally Posted by Gino /img/forum/go_quote.gif I am tossing between the IM716 or an Ety ER6. Among the Ety line, which one will be closest to the IM716 depodded? |
er4p: 27ohm
er4s: 100ohm
er6i: 16ohm
Good luck.
