Dadracer
- Dec 20, 2012
Oh no that means I might have to get 2 now!!!
Or you could go the whole way and get an iUSB and use it with the gorgeous Gemini cable..........
USB 3 is used for two reasons: Better quality connectors and better quality (shielded etc) cables. USB 3 doesn't have every Chinese factory putting out 15M $.001 connectors, so it's easier to source good quality components. As well as cable requiring much better shielding (and extra conductors for the 4 extra USB 3 pins.) If you don't have a well built connector and a cable up to spec, the USB 3 connection will cause 2.4ghz interference - plug something in and notice your old wireless phone or wifi drop...
The extra pins allow full duplex operation, which I guess is not required for this application. But better connectors and shielding sounds important for eventual SQ. My point was that if iFi is soon to upgrade its cables to USB3 - so matching the sockets on the iUSB3.0 Which would seem a consistent move. Then just now might not be a good time to buy the existing USB2 versions of these rather expensive cables?
