Like getting a new kind of maths question right without having seen a solution...
Hi,
Simple notes on arranging iP2 in system:
1.) iP2 on its own - always place iP2 at the DAC/USB Device input socket
2) iP2 with original iUSB Power - depends....
2.1). DAC uses USB Power only for Handshake (e.g. iFI Retro, DP-777), place iP2 at the DAC USB socket AFTER iUSB Power
2.2) DAC powered by USB (e.g. iDAC 2, iDSD in USB Power Mode), place iP2 at the input socket to the iUSB Power
3) iP2 with iUSB 3.0 - iP2 is redundant, but can be used at the USB Input of a USB 2.0 DAC, iP2 not likely to improve anything
4) iP2 with other manufacturers' USB gadgets - always place iP2 at the DAC/USB Device input socket, unless the other gadget is felt to give superior results after iP2
5) Two iP2s - the second iP2 is redundant, but if it is desired to use longer cables placing the second iP2 between a USB Cable and USB extension can make sure signal transmission works well (as it is an Active Repeater).
If using multiple iP2 in series (up to 3pcs) with standard USB2 ports and USB Bus powered DACs it may be best to place an iUSB Power or iUSB 3.0 in the final position, both to provide clean and sufficient power and to break earth loops.
Cheers.
