abvolt
thanks thats what I was looking for..
Thanks for the reply however i'm using the IFI idsd Black label
Late to the party but I love this device to bits especially the NOS/Bit-Perfect is really nifty on a traditional chip-based DAC! On top of the smart triple optical/coaxical/input, the DSP switches, the power on it is just insane for a semi portable device too! Great op-amp in it no clue whatever kind it is, it is insane.
I'm always using it in battery mode and charge it when I'm sleeping. Beats having to see if a linear power supply exists for other desktop gear, it's hard to beat battery power performance characteristics!
In any case my conclusion is this device is very very hard to beat. In NOS it sounds a little warm-rolled off, especially compared to other ESS Sabre DACs, but it also sounds very natural and pleasing. I wish my PC could sample to DSD 256/512 but alas that might be for some years later in the future, I'm sure I'll still be using this little device for years to come hats off to iFi.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Hi I think I have a problem.
(RE Silver version of the Micro idsd /Win 7 /foobar)
I am not able to get the audio control panel to identify the correct sample rate of hi rez flac files. In foobar a file is recognised as 192000Hz but the control panel shows 44100Hz.(see below). Also the led is green. When I play DSD files the control panel indicates the the same sample rate as shown in foobar for example 2822400Hz (led light blue).
Any advice most welcome.
Which output driver are you using?Thanks for taking the time to reply. I am not having problems with DSD files The audio control panel sample rate corresponds with that shown in foobar eg dsd64 file shows sample rate of 2823400 in foobar registers the same sample rate in the audio control panel. However if I play a hi-rez flac file eg 192000Hz is displayed in foobar but only 44100Hz is displayed in the audio control panel. Any ideas. Thanks
Hi technobear.I am using AsioWhich output driver are you using?
Asio? Wasapi? Direct Sound?
Well then somewhere in your ASIO configuration, you have limited output sample rate to 44,100.Hi technobear.I am using Asio
I'm away from home so I can't just fire it up and look. Sorry about that. I know it can work so it is misconfigured somewhere.
