TheoS53
- Mar 17, 2014
I am considering iDSD Black Label, did anyone compare idsd BL to NFB 11.28? Does idsd BL has multibit DAC chip?
@jeffhawke should be able to tell you about that
Well, first of all, I find it kinda difficult to carry the NFB 11.28 around... Jokes aside, I don't even have the NFB 11.28, but the 28.38, which is in a different market segment, as it has a fully balanced configuration and a very powerful amp section. Having said that, I love the iFi micro iDSD, I've changed a few desktop amps but I always kept my BL. It's Burr Brown twin DAC section is superb and I don't know if it is multibit or not, but it has a "bit perfect" switch which I keep on all the time. Power-wise it is definitely no slouch, in fact it comes close to the 28.38. The BL is definitely more suited for iems, even very sensitive ones, the 28.38 loves big, higher impedance cans. So, depending on your intended use you may choose one or the other, for desktop, full size balanced headphones I have chosen the 28.38, for iems and single ended cans the micro iDSD BL. Both also have analog outputs (the 28.38 XLR and RCA, the BL only RCA), which allows their use as pure DACs. On a single ended basis, I think the micro iDSD BL has a slight upper hand vs. the 11.28, and it is certainly much more versatile.I am considering iDSD Black Label, did anyone compare idsd BL to NFB 11.28? Does idsd BL has multibit DAC chip?
https://www.head-fi.org/threads/ids...ase-info-page-153.711217/page-5#post_10404689Does idsd BL has multibit DAC chip?
It looks like a hydrid dac chip.
Hi All
Really hoping you guys can help me but i've got the flashing blue light on my idsd black label.
I have tried plugging it in to a usb power source (in my case my iPhone charger) for an hour, unplug wait 30 seconds then re plug. Have tried this 3 times but it still gives me the flashing blue light.
Am i doing this right? stupid question but i plug the provided blue usb cable from the digital input into the power source and not plug in a male to male usb to the smart power output on the side to charge the unit.
Am at my wits end with this thing. Love it when it's working but i then didn't use it for a month and now having annoying dramas trying to "jump start" this battery.
Any help will be greatly appreciated
Thank you for your reply. Tried all that, still flashing blue light. Left it on "charge" all day and still not doing anything. I'm only supposed to plug in the blue cable to the digital input for charging the device right? Nothing else.Sounds like you've got the cable in the right place. Unplug it, try turning the device on, see what happens. If it looks like it's acting normal again, turn it off and put it back on the charger. If you turn it on and it still doesn't do anything, leave it on the charger for a couple of hours
http://support.ifi-audio.com/Thank you for your reply. Tried all that, still flashing blue light. Left it on "charge" all day and still not doing anything. I'm only supposed to plug in the blue cable to the digital input for charging the device right? Nothing else.
Frustrating me to no end.
Because you are using the wrong port. The main one is the digital input. The charging port is the smaller one to the right (the micro USB).
It has a battery symbol above it with "5V". You need a USB to micro USB cable - there isn't one included in the accessory package, but any standard micro USB charge cable will do.
I had the same issue with mine. In the end I sent it over to iFi for PCB replacement because none of their troubleshooting tips worked.Thanks for the reply however i'm using the IFI idsd Black label
Hi All
Stay updated on iFi audio at their sponsor profile on Head-Fi.
