329161
- May 5, 2012
What are the physical dimensions of the BL? Pretty much the only thing holding me from pulling the trigger vs the Mojo is portability
I measure 2.5" x 6.0". I actually like it as a portable over the mojo. The idsd is very similar in dimensions to my phone, just thicker. The mojo is more awkward and doesn't stack as well. ymmv
From the iDSD manual:
PCM (digital filter) Bit-Perfect Minimum-Phase Standard DSD (analog filter) Extreme Extended Standard
On my unit playing DSD files, Standard sounds brightest and Extreme starts cutting off at a much lower frequency. The manual says to select “Standard” for measurements for both PCM and DSD. My thinking is that the Standard filter (digital for PCM and analog for DSD) lets "the most through" and will therefore measure better (insert much hand waving here).
My original iDAC2 actually had the analog filter settings reversed (brightest on Extreme, dullest on Standard). I couldn't say for sure what the behaviour of the digital filters was. iFi sent me a replacement unit and the DSD filters now behave the same as the ones on my micro iDSD.
Hi @iFi audio
I haven't been able to see if this was clarified at all, for the iDSD vs iDAC2. Particularly for understanding the iDSD DSD filters.
Appreciate if you can help !
Cheers
Hi all, another question
Does an Audioquest Jitterbug female end nicely into the iDSD's male USB port?
Thinking of going direct from USB hub to the iDSD with a hard adapter. The Jitterbug's build quality would be better than any of the cheap hard adapters out there.
If anyone could try and take a photo for me, that would be greatly appreciated !
Cheers!
Forget Jitterbug. The iPurifier2 Type A is the one you want.
++1
I love my "old" micro idsd...........would have a hard time justifying a purchase of the new one. I would love to see an owner's comparison of them. Has that been done yet?
Thanks mate, but I'd still need a cheap hard adapter to go with the iPuriifer2. As above, I don't really need the Jitterbug for it's jitter stuff.
I'm looking for a well made type A female to type A male adapter. The Jitterbug is that, but somebody has told me recently the Jitterbug doesn't fit into the iDSD sadly.
What hard adapters are people using? I've seen posts where people have opened up those cheap hard adapters from eBay and they'd used steel wire inside.... eep
I'm looking for a single hard adapter to go between a microRendu and iDSD.
The iDSD comes with a blue USB cable male A - female A. It's a very good quality cable that you can use between the mR and iDSD.
Do note, your mR will get very HOT. It measures 39C when used with my yggy, but reaches up to 45C in just minutes with the iDSD. Unless you use battery mode, but it will mean you'll have to charge it elsewhere when not listening. Just thought you should be aware.
Understood, the iDSD needs 5V VBUS power continuously, so the LPS-1 feeding the mR will probably run warm too.
It probably will, although I use the HDPLEX instead of the LPS-1. But it's the mR that iconcerns me. Admittedly I'm one of those guys on the mR thread who doesn't like the mR go red hot, so it depends on what your comfort level with heat and electronics.
Back to the iDSD, it's supposed to have a smart feature that stops drawing power once the battery is full. So I dunno whether it's entirely true that it draws power continuously.
