gr8soundz
- Jun 28, 2014
So I connect a Teradak Power Supply to the wall & plug a usb cable from it to the USB Regen (which also has a power adapter connected to a wall plug) & another USB cable from it to the Micro iFi?
also isn't the AudioQuest Jitterbug just another version of the iFi iPurifier, which is supposed to already be inside the Micro iDSD?
Confusing isn't it?
Only way to know for yourself if or how much better it all sounds is by hooking them all up at the same time then swap/remove/shift things around.
Might actually be fun if all those pieces (just for USB) didn't cost $350.........
