ImperialBlade
- Oct 5, 2013
Has anyone used an iMac or phone (Android of iOS) as a source to stream music to the iDSD Mirco? I am talking about music streaming services like Pandora, Amazon, Google, or Tidal?
I am pretty sure the iFi IDSD Micro come with what you will need, meaning a included 3.5mm to 3.5mm standard jack for connection to mobile device. That you *may* want to upgrade in time but it should get you going.
Two things. 1) I would say fair enough but neither is the Burr-Brown chipset used in other high-end DACs. So it has a less than desirable chipset too. 2) At the end of the day, it is a swiss army knife (portable/desktop) and saying it isnt a chainsaw (pure desktop that is up to full dedicated tube amps) is somewhat at odds with its remit (and price/performance). For me, when I get home, I put it in the big rig and then disconnect when I go out. To ask it do Class A or A/B switching and so on is just beyond the bounds of reality. Happy to stand (or sit) corrected.
Thx. Do I connect the devices via otg cable or through 3.5mm to 3.5mm?? Why do u say I may want to upgrade in time?
Hello MunDa,
You would use the 3.5mm to 3.5mm if you want to connect your Note to the Micro.
As far as upgrading, that is an option that could improve sound. Like using an Oxygen Free Cable made of silver. In many cases this improves the sound quality in music.
Regards,
Eric
A list of standard USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note3:
stock Samsung Galaxy Note3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/7Bvkhz
from here: http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/6060#post_11190932
You will need a USB OTG cable with a USB A Female termination to insert into the iDSD.
How does one insert a female termination?
The micro iDSD has a recessed USB A Male plug. This was chosen to match the Apple CCK/Lightning cable.
micro USB OTG to USB A Female cables are readily available.
Make sure the cable is 'OTG'. Regular types won't work.
