Gamerlingual
Well, one thing I can say about iFi, at least their customer service seems solid. Cheers
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Hi,
Im considering buying the IFI Hip Dac and was wondering if and how i can connect the FIIO BTR3 (Bluetooth dac) with the IFI Dac? Will the USB A to USB C cable, connected to BTR3's USB C port, as a source work? The IFI doesn't have a 3.5mm line so not sure how to connect the bluetooth receiver to the dac! Idea is to use the BTR3 as a input source (via bluetooth) for the IFI DAC.
Any answers much appreciated!
Sidenote- My Huawei p30 pro works really well with the BTR3 transmitting aptx/LDAC over bluetooth. Using the Audio Technica M50X or FH7's is never a problem. However, i recently got the Tin Hifi P1's and BTR3 doesn't really put out the best possible output. I travel quite a bit and was considering buying either the IFI Hip Dac or the NX4 DSD to power the P1's and maybe Hifiman Sundara's (sitting in the cart).
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
I've noticed crackling sounds in my IEMs when connecting and disconnecting them from the hip-dac even when it's switched off.
I don't know if that means that the device delivers voltage to them even when it's switched off.
Thanks!!Well, they are both DACs, and as you noted the BTR3 type-C is an input not an output (ditto the USB port on the iFi, of course)--I would say you should simply consider a different iFi product with line in capability in addition to / in place of DAC function. Plenty to choose from right @iFi audio ?
One of the product reviews mentioned that if you leave the iems are left plugged in (after switching off), they drain the battery out. That could probably mean that the iems receive power despite switching off. Maybe that's causing the crackling?
Yup! @Mozbach I encourage you to take a look at xCAN. Not only it has single-ended and balanced line inputs, but also a wireless receiver and DAC inside. If you'd like to know more, please feel free to ask!
A small part of the first batch had a defect. If one has a unit that drains battery when powered off, we replace the whole product.
IFI Xcan is a bit off budget for me...maybe will delay the purchase for the time and buy the xcan when i can! Thanks for the tip!
Do you have a serial number range
Is it safe (for the battery) to keep the DAC connected to the computer's USB at all time? even when not playing music?
Thanks
FiiO has good service, but their installation instructions can be hard for me to understand. The people at Sony under support try to use too much marketing jargon to explain the benefits of their products which is annoying because they can't really answer the information correctly. At least you guys keep it clear and concise and know what you're talking about (well, to me at least)Thanks! What about the rest ?
I always disconnect it after each use. It helps preserve the battery. Still a nice little gem that hopefully can still benefit from a firmware update from the battery.Is it safe (for the battery) to keep the DAC connected to the computer's USB at all time? even when not playing music?
Thanks
