rudy49
- Nov 15, 2013
@rudy49 Someone can correct me here if I'm way off, but that warning is a network issue, not specifically a ZS issue, meaning you've got some things to work out on the network side of things.
I am not sure what In all you are running there but I always see other windows open in the screencaps you are posting, and I also use a Mac and again I have no idea if these things are running or not, but you have an awful lot of icons in your menu bar, and indications of other programs open that can contribute to your streaming quality.
Try disabling all those things running and close all windows but your streaming source and see what happens...
Cheers!!
hello@rudy49 Someone can correct me here if I'm way off, but that warning is a network issue, not specifically a ZS issue, meaning you've got some things to work out on the network side of things.
Cheers!!
i shut down the VNC and Dropbox which are the icons that you are seeing. Safari is the only app. that i use during streaming. why i continue to loose the connection on the ZS yet the track will continue to play from Tidal on my MacBooks speakers to the end is a mystery. are you saying that the "server error" message is not coming from the ZS but is being generated by Tidal? at Tidal's request i tried mode 3 and this did not resolve the issue. i am having my ISP upgrading this morning. new router with a promised 70/70 Mbps. download speed to insure that my end is covered. its either the ZS or Tidal that is causing the problem. or a compatibility issue between the to. a main selling point of the ZS is its ability to work flawlessly with Tidal. Tidal is very interested in helping me resolve this problem since it is in their interest. Ifi has suggested that i exchange the unit. i had to buy this from TREO in Singapore since the distributor for IFI here does not carry the ZS. i want to exhaust all possible solutions before i throw in the towel. hopefully i will hear back from Tidal today and i am sure that they are in communication with IFI to make some changes to their respective app.s if necessary.
cheers.
