Hi @iFi audio. I am planning to buy the Zen can signature. I have some questions:
1. How much better is the balanced output compared to the single-ended output on the Zen dac singature in term of sound quality? I guess 10-20%, please correct me if I am wrong.
2. If I use my Audeze LCD-2's 6.3mm cable, is it better to connect the Zen dac with the Zen can via single-ended (RCA) cables? I think the circuit on the Zen can has not to convert the signal (ba to se) thus better outcome sound?
Thank you!
1. I'd say it's about 10-20% better if you'd like to put a percentage to it! It varies from headphones to headphones.
2. You can use either the balanced or the RCA connection, it's a separate set of circuitry so if you used balanced or RCA on the back it does not affect balanced or SE on the front (if that makes sense)!
