iFi audio xDSD- The Official Thread
- Thread starter iFi audio
- Mar 20, 2013
Hey folks, check out what I just got, iFi's cool new 3.5mm to 6.5mm adaptor!
It's a perfect pairing!!
Looks really good!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
- Mar 20, 2013
Another attempt on making my own mini OTG cable.
Every effort counts and that OTG you did (even though a bit bulky) is better than a regular cable to us and looks clever.
Earbones
- Dec 21, 2013
Has anyone experienced a random bricking from charging?
I got my xDSD yesterday. It arrived about 50-75% charged. I listened to it for about an hour, mostly just comparing it to the Nano iDSD and Chord Mojo... Fantastic sound.
I was planning on using it all day today, and I wanted to top off the charge. So I turned the unit off, and then plugged it in via the USB-micro charging input, using an appropriate cable and an outlet adaptor rated to the correct voltage.
The correct light came on, so I assumed it was charging as outlined in the instructions. But when I checked on it like half an hour later, it was dead.
Even if there was something wrong with cable or the wall adaptor, and the unit wasn’t receiving a charge, but just sitting there, somehow using battery, it still shouldn’t have been dead... It had enough charge for a couple of more hours of run-time.
Now the unit won’t power on, and attempting to charge it with different cables and other correctly-rated wall-warts does nothing. No charging light comes on at all now. The unit is bricked.
Anyone run into this? I tried to outline above precisely the steps taken- did I do something wrong?
My first guess is the battery (or more likely the charging circuit) might have been damaged. Try plugging it in to a PC (via the USB-A) and see if it powers up or not. In any case, you best bet is to contact iFi immediately, and perhaps stop using that particular outlet adaptor for the time being..
Earbones
- Dec 21, 2013
Oh yeah, I haven’t used that initial adaptor or cable since that first charge. I actually used a different outlet too, ha ha. I’ll probably just send it back to Amazon rather than going through iFi...My first guess is the battery (or more likely the charging circuit) might have been damaged. Try plugging it in to a PC (via the USB-A) and see if it powers up or not. In any case, you best bet is to contact iFi immediately, and perhaps stop using that particular outlet adaptor for the time being..
Bansaku
Looks really good!
It's not only identical in colour and finish, but made of the same metal! (I admit, I did the trusty mouth test)
Bansaku
Ooooh, yet another victim of using a 3rd party USB cable...
Not judging as both my wife and I have killed several USB devices with shotty cables.
Remember folks, not all cables are equal!
Bobpaule
- Nov 5, 2004
Can't say enough good words for this little device, all my 3 Squeezebox Touch and now the xDSD are each powered by one of these, $50 well invested IMHO, and YES it does have a micro-USB adapter included:
From Kalman:
https://www.stereophile.com/content/music-round-77
From Kalman:
Earbones
- Dec 21, 2013
I dunno. The cables I used are all Sony-branded... They came with PlayStation controllers.Ooooh, yet another victim of using a 3rd party USB cable...
And the xDSD doesn’t come with a charging cable for the micro USB input, so technically any cable I used was going to be a 3rd party cable...
I feel you on bad cables, though. I try not to get the cheap ones...
Bansaku
My PS3 USB cable messed up my XBOX One controller, and killed my vape unit...
I have learned to use only what is supplied with the product. At best they simply won't work, but why chance it. Sure, schiit happens, but better play it safe, especially with used cables with expensive devices.
Earbones
- Dec 21, 2013
Preaching to the choir. But again, iFi doesn’t include a USB charging cable with the xDSD... If they had, I’d have used it...My PS3 USB cable messed up my XBOX One controller, and killed my vape unit...
Bansaku
What what what? If anything iFi included too many cables with the xDSD, including a charge cable... at least mine did in which I am currently using. That does not seem right. This is seeming more and more like an Amazon issue, though I am 100% positive iFi will make things right; They always do which is why I hold the company in such high regard.
spdtdl
Formerly known as Free1066
- Dec 24, 2015
No charging cable with mine. Also just watched an unboxing on YouTube and no charging cable?
Bansaku
Serious? Hmm... well then. Guess I am special!? Damn, will have to wait for @iFi audio 's response before I make any more statements I can't back up.
P.S. Booya! this post is my 1000th!
