Did you pick one of these up, Matt? I was thinking of getting a cable from you to go from this to my Onkyo DP- S1.It probably has to do something with their smart battery charge.
iFi audio xDSD- The Official Thread
- Thread starter iFi audio
- Mar 20, 2013
It may be in the desktop mode.
Indeed.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I use it on BT all the time but I see the green light flashing while charging. How would I get off of desktop mode?
Devodonaldson
As I stated earlier. Whie charging, I never get a white flashing light. Eventually light will go out. At that point I unplug DAC from power and turn it on and load up music. Either white light turns green after about 1-2 minutes, or upon turning on, it goes straight to green light. It's making me think that my device is not getting fully charged. Is it possible to still be in "desktop" mode if it's running off of battery, or do I possibly need to send my device back?Indeed.
- Mar 20, 2013
It's for the best to ask us here: http://support.ifi-audio.com
If in doubt, that's the fastest way.
Hey guys. Hopefully someone can help...
I have a pair of Roxanne II IEMs, and they have a balanced cable, with a 2.5mm connector. The XDSD says it has a balanced option, but the socket is 3.5mm; is there a way to connect my balanced cable to it?
Please forgive my ignorance... I am relatively new to all this.
Thanks.
Thanks.
Mimouille
Either you buy a new cable with Roxanne termination and 3.5 TRRS balanced jack or you buy and adapter, female 2.5 TRRS to male 3.5 TRRS. Be sure to say you want to 3.5 TRRS balanced because 3.5 is also single ended TRS. All cable makers can do bothHey guys. Hopefully someone can help...
Thanks.
Thanks. I have seen some online now.Either you buy a new cable with Roxanne termination and 3.5 TRRS balanced jack or you buy and adapter, female 2.5 TRRS to male 3.5 TRRS. Be sure to say you want to 3.5 TRRS balanced because 3.5 is also single ended TRS. All cable makers can do both
Do you think it would be worth it, for IEMs (short cable)? Some say it is an improved sound.
- Mar 20, 2013
Mimouille
I am not a big cable believer. But the most straightforward solution is a new cable, not the adapter.Thanks. I have seen some online now.
Devodonaldson
Anyone with SE vs Balanced comparisons with the xdsd
jsmiller58
Help...
Setup:
iFi xDSD (FW 5.30)
LG v30
Connected over USB (not BT)
USB Audio Player Pro (playing Tidal)
Playing known MQA tracks (I get MQA out of my desktop DAC on the same tracks, but using the Tidal app, not uapp), but not getting MQA out if the xDSD)... the frequency light stays green, so not playing MQA.
Looking at the track playing the info shows it is not seen as MQA, though I know for a fact it is... so not sure if my USB Audio Player Pro settings are set correctly (my guess is probably not set correctly but I don’t know what they should set to), or if somehow the xDSD is forcing the uapp to not be in MQA mode (doubtful)...
Can anyone explain what might be going on? Probably best place would be to start by explaining what options I need to have on in uapp...
Thank you in advance!!!
Setup:
iFi xDSD (FW 5.30)
LG v30
Tidal only plays MQA through the desktop app. There's talk of MQA over mobile devices, but as of yet, that's not possible.Help...
Setup:
iFi xDSD (FW 5.30)
LG v30
It is with the V30, it has MQA decoding built into the F/W and works very well. I've never tried the V30 connected to an MQA renderer, that may not work as expected
jsmiller58
Well, now that is both clear and disappointing! Thanks, I appreciate the prompt reply...!Tidal only plays MQA through the desktop app. There's talk of MQA over mobile devices, but as of yet, that's not possible.
Having said that, what are the optimal settings for UAPP to get the best sound / performance out of it through the xDSD?
Thanks!!
