What's your setup like for network? I can't make Pro iDSD force Ethernet.
I can't either. The only thing to do is never set up the wireless, or take off the arial.
Would be greatly appreciated.
Why? What exactly would it tell you?
Distortion numbers don't say anything about a product's performance. I wouldn't say it's an unreasonable request, so much as it is a pointless one.
I prefer a low noise floor in my products, so yes- measurements matter.
@iFi audio - Are there plans to make the Pro iDSD in a black case version? The latest Music Direct catalog I got shows it available in both. If so, when will that be available?
Thanks!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
It is hard to hear difference between Wi-Fi and USB.
The source is Spotify.
In short, no. It's very unlikely that the pro range will arrive dressed in black. This colour is reserved for our Black Label products, hence substantially improved versions of original items and to have the Pro range any better than now will take A LOT of time.
Measurement figures are usually taken off the highest distortion peak, or taken at a given frequency, such as 1kHz, so they don't actually tell you the noise floor. Also, the impedance of the testing device, the particular output used, what bit-rate was tested and other things will affect things as well. It would be more interesting to have someone like Atomic Bob do a full set of measurements and comment.
It's a bit Captain Obvious
