dericchan1
Thanks IFI for confirming. Dark orange is what I have.My bad, your post was about the LED on the iPower Elite. As for its color, dark orange is the one, thanks!
Cheers
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I always liked coaxial over optical. Give each interface a try and see which one you prefer.
Roger that and, by the way, it looks as though I may "have" to replace my PRO iCAN Signature! That Phantom looks "splendifirous" and I've always wanted to get back into electrostatics ever since I owned some self-powered early era Koss ESP-6A phones back in the early 1970s..That's what we suggest too, thanks!
Roger that and, by the way, it looks as though I may "have" to replace my PRO iCAN Signature! That Phantom look "splendifirous" and I've always wanted to get back into electrostatic ever since I owned some self-powered early era Koss ESP-6A phones back in the early 1970s..
My wife is going to 'kill' me! Have a good day!In that case iCAN Phantom is something worth considering and possibly auditioning
Thanks!
You are correct.Am I correct to assume the +9db, +18db are exactly just that, a bump up by +9db, +18db, no extra bass boost or anything so it’s the same as using the 0db gain but crank up the volume by 9db = 9db toggled on?
Thanks
Deric
Thx - was having the same "general" question. So I as I don't listen at high volume, I har also used this "trick" with other amps - that is using Roon to scale volume by (for example) -12 dBYou are correct.
