deanorthk
finally got ifi audio USB cable after 3 months delay, long enough so I can safely connect my idsd dac to my computer.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Guy, just got a quotation from my local vendor.Yes I believe you can ask the vendor you got it from to send it back for repairs. Cost wise...............![]()
Do u guys think it worth repairing just for the damage screen? Cause sound wise is not affected.
Yeah I agree too, mine is getting old and the screen is starting to get a bit weird too. But I can see the settings relatively clearly still, so will just live with it..It depends on how much your current screen bothers you the way it is now. It doesn't affect sound in any capacity, so if you're okay with how it looks like as is, I wouldn't fix it if I were you.
Right.. I think I’ll try to sell it and upgrade to the signature series..Yeah I agree too, mine is getting old and the screen is starting to get a bit weird too. But I can see the settings relatively clearly still, so will just live with it..
$1000... no no.
This issue is a big no no for a device which is 3k +....It depends on how much your current screen bothers you the way it is now. It doesn't affect sound in any capacity, so if you're okay with how it looks like as is, I wouldn't fix it if I were you.
I think TIDAL Connect still doesn't work. Could test it after work, when i am at a friend of mine.Hi, Ifi idsd pro can do now Tidal connect from phone app? With wifi if possible
My unit is just send by store but I don’t asked is this option is now available.
Streaming is where ifi dropped the ball on the otherwise perfect idsd pro, I not sure if it's hardware limitations or the software implementation but the software they used at first sucked the newer software is a improvement, to me blue os would have made for a better user experience.Idsd pro using wiid stremer part. Is not up to todays Standads but ifi stream neo is a underrated and cheap unit for the quality if sound that is offering. I test both units and the result is night and day
Right? I've brought this up multiple times, and there's no hope of them ever going back and fixing it for v1 or v2. Maybe in the Pro Series v3?Streaming is where ifi dropped the ball on the otherwise perfect idsd pro, I not sure if it's hardware limitations or the software implementation but the software they used at first sucked the newer software is a improvement, to me blue os would have made for a better user experience.
