iFi audio NEO Stream - Sweet Streams!
Aug 18, 2023 at 8:11 AM Post #1,145 of 1,452
I did, but it made no difference. But thanks for the suggestion. I’d guessed that more memory, especially with =>DSD128, would be advantageous.
Donald
In your home network do you have 2.4ghz? 5ghz? for wifi, and also are you able to choose which one you use, or is it a mix.
Thanks,
Cheers!!
Aug 18, 2023 at 10:49 AM Post #1,147 of 1,452
I have both, but am using 5 ghz. The distance to the router is less than 3 meters.
Could you try using the 2.4 GHz band exclusively and let me know if the result is the same?
Also, I may have missed it but did you open a support ticket?
Cheers!!
Aug 18, 2023 at 2:26 PM Post #1,148 of 1,452
Cheers!!
I’ll try when back home. Yes, I have a support ticket running, both with Audirvāna and IFI.
With only Ethernet though I have the same problems.
Aug 18, 2023 at 2:34 PM Post #1,149 of 1,452
I see, my apologies I didn't realize that ethernet gave the same result.
Do you think there is any way you would be able to send me one of the files you are having issues with? I no longer use Audirvana after switching to Roon. I am curious if Roon will give the same problems.
Send me a PM if you would like for me to give it a go.
Cheers!!
Aug 18, 2023 at 2:55 PM Post #1,150 of 1,452
Cheers!!
Thanks,
I’ll do it when back home
Aug 18, 2023 at 6:44 PM Post #1,152 of 1,452
@Mr BubbaHyde
I think you didn't see my question?
I have iFi audio NEO iDSD, if I switch to iFi Audio NEO Stream will the DAC quality be the same?
I'm asking this question because I've read that NEO iDSD would have better quality.
I am sorry I did miss it.
Let me start with this I do not own nor have I ever heard the NEO iDSD so I wouldn't have a direct actual comparison for you.
That being said I have been told by friends that they prefer the NEO Stream DAC although they are very similar the NS presents a more Dynamic and pleasing sound at least to my friends that have heard both, I absolutely love my NS sound. Now some important considerations.
Are you using this in a headphone amp capacity? I ask because obviously, the NS has no headphone amp so if that is needed it wouldn't be a smart switch, please let me know if this is just a DAC-to-DAC thing, kind of a two-different animals kind of thing.
Without saying more than I can if you are just looking for an upgrade to the NEO iDSD I might hang on to my decision-making for just a bit :wink::wink:
Cheers!!
Aug 19, 2023 at 6:17 AM Post #1,154 of 1,452
I'm using it with an integrated amplifier.
I've owned several DACs and the NEO iDSD has been the best so far.
I still have some DACs here at home like the SMSL DO200MKII, but I would like to combine the quality of the DAC with the stream to perhaps eliminate the computer.
But the doubt remains if I will not lose in quality afterwards.
In my humble opinion. Just dac
Ifi idsd pro ( the largest sound ) > ifi one signafure ( nice detail on the low levels ) > ifi neo ( deap soundstage ) > ifi neo stream ( dac Inside )
Thank you for comparing the devices.
I had iFi One Signafure and I agree with you.
