Mr BubbaHyde
Sponsor: iFi audio
That might explain it...Still no success. I'm no expert but I keep coming back to the fact my DAC is also a pre amp. The only setting on the pre amp that would seem to be the one that should be selected - eg ANLG, as opposed to USB which is the one I normally use for the Brooklyn DAC - gives a horrible rumbling sound from the speakers.
Edit - It's also worth noting ANLG is the setting on my pre amp that I normally use for my turntable.
If the Analog input on your preamp is for a Phono input that can't be used for this purpose, the "rumbling" may be an indication that it is.
If that is the case then the only way to do this is like I showed in the video, direct RCA analog to you're amp, and volume controlled via the Software of the NS.
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
