Nationalizer
And maybe a NEO Amp.Hope they will develop and extend the NEO series with a pure DAC, pure amp, pure streamer (simple version of NS), etc...
The Neo Stream is in the house (again)
So far so good......working perfectly so far via the opti-box connection in NAA mode in my desktop headphone setup. Given that the first one only developed connection issues after a couple of weeks, there needs to be some considerable time before I give it the green light.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Can't remember if I posted this one but here it is, apologies if I had...I know the Neo is chock full of features and may take a while to dissect and play about with, but there are still next to zero reviews in the hifi press, or with respected prominent Youtube reviewers. Be interested to see what they make of it.
Here are the equivalent UK Amazon feetFinally settled on a set of feet that I like for the NS, for those not a fan of the vertical orientation here are some pics and a link...
I ended up preferring the shape of these, and also the exterior matched the NS a bit better than the shiny silver ones I previously tried.
They are only connected using some 3M double-sided discs, so easily removable or changeable, lol
Link...
https://www.amazon.com/dp/B09P1B4BMM?ref=ppx_yo2ov_dt_b_product_details&th=1
Cheers!!
I am pretty sure these are it, I ordered them quite a while ago, and they do look the same, perhaps they were under a different name when I ordered them.Here are the equivalent UK Amazon feet
https://www.amazon.co.uk/Tertullus-...ocphy=1007397&hvtargid=pla-1927415121733&th=1
I might try these feet - can you also send the link for the 3M discs that you used if you dont mind @Mr BubbaHyde ? Just to make sure they are the right size
Amazon UK dont have these same pads - finding 30mm pads like the ones you have seem elusive. How flexible are the measurements, I can get these at 32mm, do you think would they fit the feet or do you think a strict 30mm is required? Or they have 25.4 mm ones too.I am pretty sure these are it, I ordered them quite a while ago, and they do look the same, perhaps they were under a different name when I ordered them.
https://www.amazon.com/V-chen-Super-Sticky-Diameter-Adhesive-Mounting/dp/B0B49JNFNG/ref=sr_1_5?crid=BRVS0VIJ85GK&keywords=1+inch+3M+double+sided+discs&qid=1670510646&sprefix=1+inch+3m+double+sided+discs,aps,106&sr=8-5
Cheers!!
Any ideas Mr @iFi audio?Dunno if it's just coincidence or not, but since I did the Beta update the other day my Neo has been a bit flaky. I went on the web Gui and noticed it seems to constantly be doing wireless restarts. Sometimes the restart is successful, other times it fails and it gives a message in a red error box which disappears instantaneously. The other thing I've noticed which wasn't a problem before I upgraded to the latest Beta is that from various sources I cannot get any sound when I am selecting Analog, and using the internal DAC - the only source that it works with is Roon and I do get sound. If I switch from Analog to USB on any source i get sound!! The caveat to this I can only get sound from analog when selecting Roon from the menu, if I choose HQPlayer from the menu and use that for playback in Roon again it's only by changing from analog to USB that I get sound.
So to try and rule out that this is all related to Beta upgrade, is there a way of reverting back to the latest "normal" upgrade that is currently live?
Well there is some sort of improvement with the replacement unit using the hardwired connection, it doesn't frequently lose network connection or restart - so that's something. It still has issues however. I have caught the network light going red on just a few occasions for about 5 to 10 seconds before changing back to white when not playing, on the previous unit it would have stayed red until it was restarted.The Neo Stream is in the house (again)
