dericchan1
I am not sure what you meant by that?Based on sound too, it sounds bit perfect(1st firmware) and standard (2nd firmware) and not GTO to my ears.
Could you elaborate a bit more on this? I could interpret it in multiple ways, so please explain.Based on sound too, it sounds bit perfect(1st firmware) and standard (2nd firmware) and not GTO to my ears.
I mean the firmware (1.30) in which I received the neo sounds bit perfect. Then upgraded it to 1.35 and to my ears this sounds the standard. I compare this using memory since the latest firmware of neo enables to select which filter to use.I am not sure what you meant by that?
Are you saying the first firmware sounded like the new filter setting of 'bit perfect' or a general bit perfect DAC sound? I'm still a bit confused as to what you mean.I mean the firmware (1.30) in which I received the neo sounds bit perfect. Then upgraded it to 1.35 and to my ears this sounds the standard. I compare this using memory since the latest firmware of neo enables to select which filter to use.
it should be GTO filter since 1.25.Are you saying the first firmware sounded like the new filter setting of 'bit perfect' or a general bit perfect DAC sound? I'm still a bit confused as to what you mean.
It should be but I'm just askingit should be GTO filter since 1.25.
Sounded like the new filter bit perfectAre you saying the first firmware sounded like the new filter setting of 'bit perfect' or a general bit perfect DAC sound? I'm still a bit confused as to what you mean.
Actually I would like some verification on the bitperfect filter. 1) does it apply to both pcm and dsd sources. (My understanding is that dsd uses a discrete channel of the dac chip so it has always been “bit perfect”)
2) by “bitperfect” does it mean if you play redbook source of 16/44.1 for example, NEO will not do any internal upsampling processes prior to feeding the source to the burr brown chip?
Thanks
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Did the firmware update, now the volume knob of the Neo doesn't function anymore.
Please any help...?
Great alexeyi, that worked seamlessly. Another problem is that my is not equally bright anymore after the update. Do you have a solution for that as well?Hold the volume knob while powering on the device(hold the knob pressed then push the power on button-device must be off)to get the menu and change from fixed to variable.
