The eagle has landed!
Just tested for a few seconds at the shop, but channel imbalance seems improved by quite a lot.
Same here
Atm I can just test with my Arya on the SE output via 6,3mm Jack (4,4mm balanced cable is on the way).
First Impression:
- Channel imbalence below 9 oclock is fixed
- Sounds a bit different than the iDSD BL (in a better way)
- Sound signature is not that smooth then the one from the BL
- SE output has not that much power then the BL offers (as reference: the volume knob is at 11 oclock with my Arya in turbo mode)
- Switches for xBass and 3D+ feel a bit cheap
- xBass changed compared to the BL -> more body and more focus on the deep bass and and the bass is not too prominent (compared to BL)
I had some complains when it comes to the DAC part of my BL (a bit to smooth). On the other side, the Pro iDSD was a bit to analytic. It seems that the iDSD Signature is somewhere between those two, which is pefect from my point of view. But I need some more days to test. Just wanted to share the first impression with you
