Thorsten Loesch
Member of the Trade: Studio RaumklanG, Studio Cocktail
Size vs performance I think still the Diablo is unbeatable.
Different strokes for different blokes, I liked the sound of the Black Label better.
I tried the ZENs in stock(USB, stock smps)
Yes, well, that will put a significant performance ceiling on the combo.
Im getting a LPSU made for the internals of Diablo to replace the 3.7LIPO. With a 3.7/5A PSU.
This sounds like a REALLY bad idea. The circuit there is made to attach to a battery.
Did you try to run with a lab supply that way to test this will actually work?
I am not sure how the circuit would react to not having a battery but a power supply.
What is much worse, if the power supply is 3.7V the system will actually attempt to CHARGE your 3.7V power supply if external power is connected.
That will give interesting results and will actually disconnect your 3.7V supply completely from the unit - except for attempting to charge this supply to 4.2 or 4.3V with up to 3A current.
Again, I would not want to predict the overall outcome. Maybe everything will survive and all that happens is that you have a pointless 3.7V power supply and the unit running from the 5V at the USB-C socket.
Maybe the 3.7V power supply cannot tolerate large amounts of reverse current and gets damaged. Maybe the Unit will refuse to turn on.
If you want to use ONLY the power supplied via battery and completely disconnect USB-C, then make the owersupply 4.3V, not 3.7V. Because a FULL LiPo battery is 4.2V.
BUT, this will actually in my view still be inferior to just supplying the same kind of power supply set to 5.2V via USB-C.
From the battery connector power will pass through a switching supply that makes 5.2V (3A limited typically) that is supplied to the Unit's internal 5V power Bus, from which all the various power supplies run.
With power supplied to USB-C this power is connected directly to the the Unit's internal 5V power Bus, no additional switching DC-DC converters are inbetween, so noise will be lower.
The USBC power is another story. Not gonna go into what Im using there. Not LPSU.
Well, as long at the external supply via USB-C is connected, that is what supplies the Unit, the battery is disconnected and is being charged if need to or is completely inactive. So that is the power supply that needs good quality and you can ignore the battery.
Thor
