I just did an update through the ios app and I noticed that spotify connect drops the connection every time i try to play something and that there is no mqa purple colour from the zen dac signature....any one knows why that is happening? Is it advised to make a factory settings restart? Will that bring back the old firmware version?
As we move into the future, our devices will not be reflecting the Magneta MQA color. They will reflect Green and Blue for MQA and MQA studio.
Thank you! At least for the interesting album It's on Apple Music and is claimed to be in the highest quality.
Indeed, in my past attempts, the purity of the experiment may have been compromised by my smartphone to which iFi can connect via bluetooth along with the wired connection. Although it doesn't seem to be able to do that and iFi didn't report AAC when double tapping the power button. As for the laptop, it has no bluetooth pairing with iFi.
Bottom line, I can't figure out what I learned from the last experience...
1. disabled bluetooth on the smartphone, altogether
2. connected iFi and laptop via USB wire (USB)
3. switched the power on the iFi, everything works
4. but... when double tapping the button the pleasant voice doesn't tell you anything, it's just not there. Rebooting everything and reconnecting, didn't do anything.
I'll keep experimenting
I hope that's how it is.
But then very curious - iFi receives a signal via USB, while possibly connected via bluetooth to a smartphone, but receives no signal from the smartphone. But it works as if it is receiving a signal from a smartphone, or say it works as if it is receiving a signal from a smartphone.
I can't get this logic out of my head. I'm going to bed now.
The Go Blu is not involved in the process of deciding what codec is used. Think of it as a mirror, it will reflect whatever your phone and laptop are telling it to.
Sadly even my JH Audio Diana hisses. Solaris, Andromeda, Dorado are unausable, even at the 3.5mm output. My small Hiby FC3 is much better in this aspect.
Please get it replaced!
I bought it with the miter wonderful and expensive green leather case. Pure jewellery. Unfortunately i had to replace it because the 3,5 mm jack out was very oblique. Is this a common issue? Can I hope for a better unit?
HI,
This is not a common issue. Thanks for reporting it to us however and, do get it replaced!
