Which software? I'll try it out on my own MacBook.I've tried iFi and Quedelix on the same MacBook, with the same USB cable and on the same songs.
iFi audio GO blu - Super small. Super light. Super Sound.
- Thread starter iFi audio
Dmitriy021
In the Chrome browser you can add an app to synchronise and control Quedelix when connected via USB. This is their original app.
I mean which software are you using with the GO blu? I don't have a Quedelix.In the Chrome browser you can add an app to synchronise and control Quedelix when connected via USB. This is their original app.
Dmitriy021
I don't understand the question a bit...
On the iFi side - I'm not aware of any Macbook software, I get the bitrate information from iFi itself (double click on the power button)
On the Quedelix side - there is an app for the Chrome browser
On the Macbook side - there's the Music program settings and there's an Audio-MIDI utility to adjust the input/output quality for each connected device
The question is, which software are you using to play hi-res files, and does GO blu report 44.1 when playing hi-res files?I don't understand the question a bit...
Dmitriy021
Now I get it. The Music App, with the outgoing signal quality selected as "Hi-Res Losselless (ALAC to 24 bit/192 kHz)". Dropping the quality to Lossless (ALAC 24/48) has no effect on the received iFi bitrate.
Ok, I'll test with the Music app and Audirvana.Now I get it. The Music App, with the outgoing signal quality selected as "Hi-Res Losselless (ALAC to 24 bit/192 kHz)". Dropping the quality to Lossless (ALAC 24/48) has no effect on the received iFi bitrate.
Update: ok so here are my findings.
First, check that you're not connected to a phone or the MacBook via Bluetooth. When I connected GO blu to my MacBook and double-clicked the power button, I realised it was still connected to my phone by Bluetooth, because the voice announced 'AptX Adaptive - 48kHz'. When I disconnected from my phone (with GO blu still connected via USB to the Mac), double-clicking the power button returned NO voice prompt. But, checking in Audirvana preferences I saw the GO blu was active, and supports up to 24/96 playback:
Then, playing back a 24/96 file from Audirvana confirmed hi-res playback is working:
Dmitriy021
Thank you! At least for the interesting album It's on Apple Music and is claimed to be in the highest quality.
Indeed, in my past attempts, the purity of the experiment may have been compromised by my smartphone to which iFi can connect via bluetooth along with the wired connection. Although it doesn't seem to be able to do that and iFi didn't report AAC when double tapping the power button. As for the laptop, it has no bluetooth pairing with iFi.
Bottom line, I can't figure out what I learned from the last experience...
1. disabled bluetooth on the smartphone, altogether
2. connected iFi and laptop via USB wire (USB)
3. switched the power on the iFi, everything works
4. but... when double tapping the button the pleasant voice doesn't tell you anything, it's just not there. Rebooting everything and reconnecting, didn't do anything.
I'll keep experimenting
Yep, as far as I can tell it only tells you the bitrate when connected to Bluetooth. Rest assured you're getting full 24/96 support from the Mac as long as your software is playing files at that bitrate and you're connected via USB. If you're connected to an iPhone or Mac via Bluetooth, the max you'll get is AAC (44.1khz).Thank you! At least for the interesting album It's on Apple Music and is claimed to be in the highest quality.
Dmitriy021
I hope that's how it is.
But then very curious - iFi receives a signal via USB, while possibly connected via bluetooth to a smartphone, but receives no signal from the smartphone. But it works as if it is receiving a signal from a smartphone, or say it works as if it is receiving a signal from a smartphone.
I can't get this logic out of my head. I'm going to bed now.
tinyman392
Be nice to noobs, we were all noobs at one point in our life.
- Apr 27, 2011
That doesn’t sound right. I haven’t run into a single IEM that has any noticeable hiss with the 3.5mm jack. Might want to talk to iFi support about that.I received mine yesterday and immeadiately send it back. This thing is nearly unuasable with all of my IEMS (Solaris, Fourte, Dorado, Diana) ... hiss, hiss, hiss even on the 3.5mm jack. This is unacceptable for a 200€ device. Even much cheaper devies perform much better.
Sadly even my JH Audio Diana hisses. Solaris, Andromeda, Dorado are unausable, even at the 3.5mm output. My small Hiby FC3 is much better in this aspect.
Best you have it replaced. This is not normal.Sadly even my JH Audio Diana hisses. Solaris, Andromeda, Dorado are unausable, even at the 3.5mm output. My small Hiby FC3 is much better in this aspect.
Luigi Milazzo
Monkeyk2010
I have been listening to the ifi go blu for a couple of weeks now. Had the btr5 2021 and came from couple of different daps (cowon, astell&kern). Gotta say the sound has something special... But tonight i was thinking how would it sound through usb. So took a good usb c cable to my phone (usb audio pro player) en wauwie even better. I'd say through usb-c it's 10% better than Bluetooth (Ldac) the soundstage gets wider, en a little smoother sounding. Already loved this little gem, but i love it even more now! A multifunctional great work ifi, for me the headfi buy of the year!
