iFi audio GO Bar - The Best Pocketable HiFi System, Bar None!
Oct 26, 2022 at 7:20 PM Post #646 of 1,211
I do own both indeed. I did break out the Gold Go Bar once and find it a little warmer just sounds a bit better all around. I haven”t used it enough to do an honest comparison. Perhaps the copper shielding or maybe iFi did put something “extra” into the Gold bar besides the aesthetics. I’m just having a slightly difficult time letting this piece of art that looks like a mini solid gold bar get scratched up So I have been using the vanilla Go Bar an pursuing a case..
I doubt iFi is going to get into the case business but this seems like a natural for Miter. And there is the beautiful but so far unavailable go bar from Taobao.
Can anyone hep is get through to Taobao to make an order for the US?
Check the link below
https://m.tb.cn/h.UVlTwAH
I have tried to get in touch with Taobao but they may not be allowed to trade with US. I don’t get why they don’t sell it through Aliexpress , I have read their site with translator and one of this forums member who speaks Chinese and lives in I assume Asia has acquired it.
Any Ideals - I even contacted the leather manufacturer in Italy to no avail..
Anyway thanks for the info on the Mojo2. Before I acquired the Go Bar I was set on getting a Mojo2 but now I don’t feel the urgency anymore..
I too use it with the Stellia but my daily driver is the Utopia with a balance 4.4 cable. I bought a 4.4 cable from Audiophileninja and it is great for the price. I usually buy a variation of Cardas but didn’t want to make my cost as much as the GoBar.
Oct 27, 2022 at 5:13 PM Post #647 of 1,211
I did break out the Gold Go Bar and find it a little warmer just sounds a bit better all around. Perhaps the copper shielding or maybe iFi did put something “extra” into the Gold bar besides the aesthetics. I’m just having a slightly difficult time letting this piece of art that looks like a mini solid gold bar get scratched up.
I doubt iFi is going to get into the case business but this seems like a natural for Miter. And there is the beautiful But so far unavailable G Bar case from Taobao.
Oct 28, 2022 at 4:54 AM Post #648 of 1,211
Too bad no luck with the new MFi09S Lightning to USB-C OTG Cable and the iPhone 12 Pro Max and iPad Pro 12.9 second generation, same problem of lights going off when playback starts.
Working:
iFi included Lighting to USB-C cable, but the third one also failed on me.
Not working:
OEOTG Digital Cable Type-C to Lightning
MFi06 / MFi06S Lightning to TypeC Data Cable
As a last resort I've ordered the GUCraftsman OTG Cable iOS to Type C/USB C cable.
I wonder if anyone else is having troubles with the quality of the included cables of the iFi Go Bar, because I am not used to cables failing on me, my old and trusty Apple lightning to 3.5 adapter is working fine for years now with the same kind of usage.
Oct 28, 2022 at 5:19 PM Post #649 of 1,211
The following info - OTG cables work with iPhone and Go Bar
Hi- The Gucraftsman lightning to USB-C does not work well with an iPhone 14 Max If you have a case it probably won’t fit and without the case, It drops the connection constantly. I am a big proponent of the Gucraftsman USB-C to USB-C, which works without fail with my A* Bionic IPads. I am sorry if anyone bought it for lightning. I just got mine and will be returning.
The following are 2 lightning to USB-C cables that definitely work with the iPhone 14 Max even in the case. These are Amazon US links.
I hope this helps. Let us know if you have other positive results or M1 iPad results,
Oct 28, 2022 at 5:57 PM Post #650 of 1,211
iFi’s acclaimed DAC/headphone amps have formed a cornerstone of the company’s product range since its formation in 2012, delivering brilliant sound from smartphones, tablets, PCs, Macs and more. Last year, iFi introduced the GO blu, first in a new line of ultraportable, pocketsize DAC/amps called the GO Series; now it’s joined by the GO bar, taking the ‘big sound in a small package’ concept to a whole new level.
Like to GO blu, the GO bar is eminently pocketable, with a robust yet lightweight alloy enclosure that measures 65x22x13mm and weighs 28.5g. But, while the GO blu majors on the convenience of Bluetooth connectivity to devices like smartphones when you’re on the go, the GO bar connects to source devices via USB and focuses on pure performance. Whether you’re commuting, working remotely or at your desk, or simply travelling for pleasure, the GO bar is the perfectly portable way to make headphones sound heavenly when connected to desktop PCs, laptops, phones, tablets or any other digital source device with a USB port.
The GO bar is not the first USB DAC/headphone amp of such diminutive size, but its specification is unrivalled. Its hi-res format compatibility and sonic tuning facilities are second to none, and its amp stage is the most powerful in the world for a headphone amp of this size. Small yet mighty, indeed.
What’s up DAC?
The GO bar’s digital audio circuitry is based around a 32-bit Cirrus Logic DAC chipset with advanced multi-bit modulation. This is coupled with a customised digital filter to minimise pre-echoes and ringing artefacts, and iFi’s GMT (Global Master Timing) precision clock system to ensure ultra-low jitter, thus reducing errors and distortion in the digital audio signal.
The DAC is fed by a powerful 16-core XMOS microcontroller, which processes the audio data received at the USB input. iFi’s in-house digital development team has programmed the XMOS firmware to optimise sound quality and ensure a perfect partnership with the Cirrus Logic DAC. Hi-res PCM is supported to 32-bit/384kHz, alongside DSD64, 128 and 256, and single- and double-speed DXD. The DAC’s architecture maintains DSD data in true native form, unlike other DACs that convert DSD to PCM.
The GO bar also delivers full decoding of MQA, the hi-res streaming technology. This means that the complete ‘three unfold’ decoding process is performed internally, as opposed to just the final unfold in the manner of an MQA ‘renderer’, which makes the GO bar an excellent choice for subscribers to Tidal’s ‘HiFi Plus’ tier where Tidal Masters (MQA) content can be found.
Balance of power
Remarkably given its diminutive size, the GO bar’s analogue circuitry features a balanced design with asymmetrical twin-channel output stage. This topology, usually reserved for larger and more expensive amplifiers owing to its cost and complexity, reduces noise and crosstalk in the signal path by fully separating the left and right channels.
Rather than resort to space- and cost-saving integrated circuit solutions which compromise sonic quality, the GO bar’s circuitry packs in high-quality discrete components such as TDK C0G ceramic capacitors, Panasonic OS-CON aluminium polymer capacitors, and high-density tantalum capacitors, plus Taiyo Yuden and Murata inductors, all with excellent characteristics for high-quality audio applications. Special attention has also been paid to power supply filtering, dramatically reducing signal noise introduced though the USB input.
The amp’s design combines sonic purity with exceptional power. In fact, with an output of 550mW (into 64 ohms) and 7.5V (into 600 ohms), no headphone amp of such diminutive size can match its impressive ability to drive even tricky headphone loads – that’s enough current drive for 16-ohm headphones and sufficient voltage drive for 600-ohm headphones. Combining serious muscle with beguiling finesse, the GO bar sounds wonderful with a wider range of headphone and earphone types than any other ultraportable USB DAC/amplifier.
Adding to this versatility, the GO bar incorporates two power-tuning technologies, enabling adjustment of its output to suit specific requirements. IEMatch attenuates power to suit high-sensitivity headphones and in-ear monitors, removing potential background noise and increasing the usable volume range. Conversely, Turbo mode ramps up the gain by 6dB to satisfy more power-hungry headphone types.
Suits you, sir
Further user-adjustable sonic tuning is provided in both digital and analogue domains. Four bespoke digital filter options – Standard, Bit-Perfect (non-oversampling), Minimum Phase, and GTO (Gibbs Transient Optimised) – can be selected according to preference, while iFi’s familiar analogue processing modes, XBass+ and XSpace, can also be switched in or out of the signal path according to taste.
X Bass+ is a sophisticated form of ‘bass boost’ that enhances low frequencies without muddying the midrange, useful with earphones and open-back headphones that may lack deep bass. XSpace is designed to compensate for the ‘in-head localisation’ effect that can occur when using headphones to listen to music that was mixed using a pair of speakers, effectively widening the headphone soundstage to deliver a more spacious and speaker-like experience.
With such a variety of digital streaming platforms, file types, headphones and earphones to choose from, not to mention music styles and recording qualities, this suite of sonic tuning options is valuable to ensure optimal sound – and unique in a DAC/headphone amp of this type and size.
External affairs
Most ultraportable USB DAC/headphone amps offer little or no control via the device itself, with volume adjustable only via software running on the connected source device. The GO bar is different, its smart alloy case sporting physical buttons for precise volume adjustment – which can be synchronised with the volume controls on the source device – together with controls to select between the various sonic tuning options. A column of coloured LEDs provides a handy guide to the format and sample rate of the digital audio currently playing, and whether XBass+ and/or XSpace are engaged.
At one end of the GO bar is an asynchronous USB-C input, at the other resides a pair of headphone outputs. One of these is a fully balanced 4.4mm output, enabling headphones equipped with a balanced cable/connector to make the most of the GO bar’s balanced audio circuitry. The other is a 3.5mm output utilising iFi’s ‘S-Balanced’ technology – this cuts noise and crosstalk by 50 per cent with regular single-ended headphone connectors. Both outputs are gold plated to maintain contact quality over time.
Birthday bling
To celebrate its 10th anniversary, iFi has also created an eye-catching special edition of the GO bar. Limited to 1000 pieces, the GO bar Anniversary Edition – or ‘GOld bar’, if you will – replaces the standard version’s alloy enclosure with a copper chassis, further enhancing build quality and electrical shielding, and smothers it in 18ct gold plate. Power supply filtering is also further enhanced, ensuring the Anniversary Edition – which, at 64g, is more than twice the weight of the standard GO bar – is truly the ‘gold standard’ among ultraportable USB DAC/headphone amps.
Ready for anything
Both the standard GO bar and the Anniversary Edition come with a generous accessories pack to get the tunes flowing right off the bat. Apple users will love the bespoke Lightning to USB-C cable, engineered by iFi so you don’t need to add Apple’s Camera Adapter dongle to use the GO bar with iOS devices, as you do with other USB DACs – thus reducing bulk and cost. Android users, meanwhile, will appreciate the USB-C OTG cable, which can also be used with USB-C-equipped PCs and Macs; a USB-C to USB-A adapter is also included, thus covering most bases straight out of the box. And there’s a leather travel case too, ensuring your GO bar is well-protected wherever you choose to take it.
The GO bar is available from selected retailers from 20th May, at an RRP of £329, €329 and US$329. The GO bar Anniversary Edition follows in June, at an RRP of £499, €499 and US$499. Both will debut at the HIGH END 2022 show in Munich, 19th-22nd May.
https://ifi-audio.com/products/go-bar/
[ICODE][/ICODE]
Will the iFI Go Bar work with an iPad Pro M2?
Oct 29, 2022 at 2:34 AM Post #651 of 1,211
Hi friends,
Can you please tell me what color (LED) now corresponds to which digital filter? If I understand correctly, since the release of the last FW, this has changed? Now FW v1.70
Now I see: white, yellow, green and red. Use Gold Bar.
Oct 29, 2022 at 7:37 PM Post #652 of 1,211
The dongle format brought to the ultimate level soundwise. Well done iFi👏
I will call it the « baby Calyx M » due to its analog, warmish yet full of details tuning. A tour de force!
Oct 29, 2022 at 7:56 PM Post #653 of 1,211
Congrats- I am still in awe every time listen!
Has everyone given up on a play-through case like Taobao or has anyone found an alternative or a way to get through from the States?
I still have the wrap on my Gold Bar and it irks me especially when I know there is one being manufactured in China mad with Italian leather.
Well- enjoy your Gold Bar! I was using it today with my iPhone and the sound is amazing for Kin Dong(le).
Wouldn't it be nice if iFi, a British company that manufacturers in China found a way to make it available to Gold bar owners and others?
Perhaps they could buy 1 as a token of appreciation for every Gold Bar purchaser who can verify their ownership -
Make that every Go bar purchaser since I am in fantasy land anyway.😆
Oct 31, 2022 at 3:21 AM Post #654 of 1,211
When would you even need a case for the dongle? Carrying this chain of phone, cable, dongle, iem around? I almost see this setup as a pure stationary solution. Would go for something wireless when on the move. Or how would you carry this kit of gear tangled up in cables and dongles around in a safe manner?
Oct 31, 2022 at 3:46 AM Post #655 of 1,211
I am speaking if a play-through cable primarily for the Gold Go Bat to avoid scratches and deterioration.
Look at the link to see how it works
Nov 1, 2022 at 4:50 PM Post #656 of 1,211
Hi friends,
Hans,
I just got a Go Bar and updated to 2.20a and it didn’t seem like the filter colours matched the manual.
I think it was the bright lighting I was initially viewing the Go Bar in making the colours look incorrect.
In dull light where the small LED are more clear I see it as you indicated:
Cyan (Green) = Bit Perfect
White = GTO
Red = standard
Yellow = minimum
These match the original colours. 👍
Nov 1, 2022 at 5:55 PM Post #657 of 1,211
Definitely need a golden case for the gold bar, but for the time being, we have to wait for it.
You might want to withdraw the plastic protection out of your golden precious. Otherwise, you cannot see it in its full glory while playing your favorite tunes. Honestly, life is too short to not expose the most beautiful things to ourselves. I use a small and soft kind of tissue to protect it. It has to be handled with care, though.
This « dongle » is a pure sounding marvel. Prince would agree on that.
Nov 1, 2022 at 6:13 PM Post #659 of 1,211
One place in the USA, Listen up still has a few Gold Go Bars on sale at the list price.
I just bought the case from Taobao and paid on Alixpress. How long it takes is another question for the USA. They did not charge me a lot for shipping. We'll see.
There are 15 colors but looks like only 5 are available. I'll be glad just to get some protection on this marvel.
Nov 1, 2022 at 6:15 PM Post #660 of 1,211
Hopefully you’ll get it quickly
