I saw a comment about a usb-c to usb-c cable (GUCraftsman OTG Cable) that works with the go bar.
I am looking for a good quality third party ligthing to usb-c cable because the included one kees breaking and I am already on my second replacement.
Some others I have tried and that do not work with the go bar
- ddhifi MFi06 lights don’t go on.
- OEOTG Digital Calbe, lights go on but when play is started the lights go off.
Before I order another cable I'm hoping that someone can confirm a cable that works with the go bar.
Otherwise I am pretty happy with the go bar, the sound it provides is a nice upgrade.
I left that comment. Please consider there are different Models and firmware of the iPhone so no guarantees, I am using an iPhone 14 Max which has a large battery. The Go Bar draws its power from the device so please take this into consideration. All of these cables should work but I have read that some people were having problems with the iPhone 13 using the iFi cables.
What Definitely works for me:
-"Meenova" makes both variations- to my ear, the USB-C to USB-C was not quite as warm and detailed as the silver Gucraftsman. On some tracks yet other times they sound the same so go figure. The lightning version definitely works on an iPhone 14 Max. The Meenova is 400mA.**
-Fiio LT3 USB-C to Lightning also work well and advertise lossless support. You can feel it is a well-made cable but I spend most of my time on an iPad so I can just say they work well. (you can find the best price at Audio46)
As I have mentioned earlier in this thread- "Most of the Lightning OTG cables, which have an output of 3.3V 100mA cannot fill the need for portable DACs. 5V 200mA should work well -However, I thought the "ddhifi" is 200mA so it should theoretically work.
Gucraftsman-
I have only used the USB-C to USB-C version as the lightning Gucraftsmen has been delayed in fulfillment. However, it wasn't Prime when I first ordered.
I just went on Amazon and saw the lightning version became available for Prime fulfillment so I reordered for Monday delivery and canceled my previous order.
I have been using the cable for a couple of weeks and IMHO it is excellent in every way. It is similar to the "ddhifi" which gives me pause for concern in your application but it is 400mA.
**As I have said earlier in this thread- "Most of the Lightning OTG cables, which have an output of 3.3V 100mA cannot fulfill the need for portable DACs. 5V 200mA output should be optimal: However, I believe the "ddhifi" is 200mA so it should theoretically work.
To the best of my knowledge the above I mentioned Meenova is 400mA."
I have only used the USB-C to USB-C version as the Gucraftsmen My lightning order has been delayed in fulfillment. However, it wasn't Prime at that time.
I just went on Amazon and saw the lightning became available for Prime fulfillment so I reordered for Monday delivery and canceled my previous order
If you can get the Prime deal check out the Gucraftsman- its SQ is so very good. I can't attest to its long-term viability but it has excellent construction. You have a 30-day return window.
