PiccoloNamek
- Apr 1, 2006
He also said:
The E4C and ER4 fit the bill much more closely. The super.fi 5 pros are nowhere near neutral.
They are uncomfortable because they are massive. The blocky housing rubbed against my ears and the huge tips irritated my ear canals. The nozzle is huge so you are limited to using only their tips, none of which are comfortable, or seal very well.
I never found the 5 pros bass to be particularly flabby or uncontrolled, but it is definitely flabby when compared to the E4C. "Slower", would be the proper word, I think.
The super.fi 5 Pro doesn't have particularly more treble than the E4C, which has much less treble than the ER4. I like my music to be bright, but natural, which is why I prefer the ER4.
[qoute]Before I figured out the little trick on how not to get the iPod to distort with EQ use, I often found myself ONLY listening to classic rock because they were some of the only genres that excelled on the Super.fi 5 pro.[/quote]
I never EQ, well, not with my iPod at any rate.
The E4s and ER4s can be found for less than $200, if you know where to look.
Heh. I'm trying to break myself out of my "OMG ER4 RULZ" habit.
Originally Posted by mastercheif Like I said, im not looking for a bass heavy can, I like em' nice a nuetral. |
I'm not quite sure why you would find them to be uncomfortable, especially since the UE website shows you a second way to wear them. |
But to say that the 5 pros do not have tight, controlled bass, I believe is a farse. |
The treble is also very nice and clean and defined, and with no iPod EQ setting is very noticable with no sense of overpowering high end. The cymbal crashes are clear and defined and do not blend into a cacophony of high-end chaos. To prove that, put on a Steely Dan track (also classic rock, which is the genre he likes) and listen to the natural sounds of the drums. I think the Super.Fi 5 pros EXCEL ESPECIALLY in music recorded originally in Analog, which is why I think Classic Rock is a perfect fit for those IEMs.... |
Based on budget however, I arrived at the conclusion that the Super.Fi 5 pro would be best for you. |
Originally Posted by 223 But even still his post is not the be-all-end-all recommendation. However, instead of unanimously recommending one of the IEM's, he pushed the OP in the right direction. |
![wink.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/wink.gif)
