ā¢ When I received delivery of HP8 Signature from Audioarcan (
), I let āocdā take over awhile: with isopropyl alcohol + q/tips, I cleaned tube sockets, RCA input sockets, IEC power prongs. Then, a SR Purple fuse replaced the stock fuse. Then, octal socket savers were placed in V2, V3; nonal socket saver was placed in V1. All socket saver pins were cleaned prior to socket saver placement.
ā¢ An added benefit of these socket savers is the increased dissipation of tube heat due to tube base elevation. Even after several hours of amplifier use, the transformer cover and the copper plate are only mildly warm.
ā¢ For tube ārollingā, there is much information in this thread. I heartily recommend the use of 12AT7 / ECC81 / ECC801 tubes (
mu: 60x) over 12AX7 / ECC83 / ECC803 tubes (
mu: 100x). This is mentioned in the Icon Audio materials with the headphone amplifier. Less gain ==> greater amplifier circuit headroom ==> less chance for compression on musical crescendos.
ā¢ Also, use a high quality power cord. When breaking in the amplifier / tubes / etc, it is preferable to use music at low volume.
