Thanks for the impression jamato8, I ought to try it out in the next few months.
iBasso T5 - A newly designed small portable. Specifications.
- Thread starter jamato8
jamato8
jamato8, any nice pics you can share?![]()
I will try and get some up pretty quick. Compared to the iRiver H120, this amp is small. I was curious, because the internal amp of the iRiver isn't bad, how they compare and that is fast an simple and the results were that everything increased in quality.
interesting impression, jamato8
does this amp compete well with corda 3move or pico? *or any other higher end portable amps
I haven't had the 3move but I had the Pico Slim. I didn't like the top end of the Slim because there was bit of grain or digital edge. The T5 has a digital volume control like the Slim but the top end is very clean and extended.
JiPod
- Apr 1, 2009
Well I have received the T5 and the sound is different. An improvement over the past T models. There is a larger soundstage, more spacial information is presented and the amp just sounds more powerful. The fit and finish also step up a good notch. Overall, it just looks, feels and sounds like a higher quality product and I had no real complaints with the T3. It is also nice to have LED's that are visible but not blinding. :^) While the other T models weren't overly bright, this one for the charge and "on", are nicely muted but obvious. The input and output also have a nice solid click to them. The case being made of stainless steel and the zinc frame, with what appears to be a thin rubberized coating would make this battle worthy.
I am using an iRiver out to the T5 (lossless) and the ESW10 and it makes them sing.
Sounds quite enticing.
Have you had the opportunity to listen to the FiiO E11? If so, please share your insight.
I was contemplating the E11 to power a pair of HD25-1-IIs.
jamato8
I haven't heard it.
The push buttons for + and - for the volume works great. Carrying the amp in my pocket there is no way to change the volume by accident and with the 64 steps, there isn't too big a jump at any time. Nice. I wasn't sure I was going to like the push buttons but they work fine.
JiPod
- Apr 1, 2009
I haven't heard it.
Is the T5 similar in SQ and/or Sound Signature to any portable amps you have heard?
superjohny
- Jun 4, 2005
I am very interested in this but if there is significant better performance in a TTVJ Slim, I am willing to pay some more.
jamato8
I have a little over 100 hours now on the T5.
The sound has gone through stages, when compared to the output of the iRiver for differences rather than relying on memory of how they sounded different. At this point the T5 has opened up quite a bit, showing excellent transparency and detail. The high frequencies are a little surprising to me as I didn't know which way they would go. The highs are very natural and open. The bass presentation is stronger than the past T models. It is not an emphasis that drifts into the lower mid but you can tell there is power behind it. The low end also seems to go lower. I can tell that this T has advanced, which is what new models are supposed to do but many times end up as just a variation rather than a true step up. I am still not unhappy with the T3, but I can tell that the T5 is more powerful and conveys the music with this solid platform behind it.
Saintkeat
- Jan 23, 2009
Sounds very promising.. Truth be told I'm tempted to pick it up, if not for the PB-1 in my bag...
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
You mean your PB-1 is in your bag all by its lonesome? How heartless of you! Go out and buy a T5 right this instant to keep it company...
jamato8
What is amazing is that the T5 has some of the best bass response of the iBasso amps. Very well controlled with actual bass notes down low and it stays out of the way of the rest of the music. I was also sure I wasn't going to like the digital volume control, with relation to the upper frequencies of the sound so I was prejudiced against it but I was wrong. This is a very fast sounding amp, with a great frequency range all coming through as very transparent.
Saintkeat
- Jan 23, 2009
HAHAHA! I might spring for one when I can afford to. Not sure what use I'll have for it unless I sell off the PB-1.
trentino
- Aug 22, 2009
Jamato, had time to take any pics yet?
trentino
- Aug 22, 2009
Since the t5 seem to have quite a bit of power I guess it should work fine with grados? I don't have an amp to use with my rs2i, It's a hazzle to use the pb2 with both high and low imp cans with the gain switch being inside of it. I'm looking for an amp to use with both iems and my Grados. Been eyeballing the p-51 for like a year now, but maybe the t5 is an alterenative?
jamato8
I now trying to get more of a handle on the sound of the T5 but I had some sort of inner ear infection for a few days, which throws everything off. Recovering now, thank god, and getting a feeling for the sound again.
I like the two push buttons for volume as you would have a hard time changing them unless you intend to and it is easy to feel which is + or - as the + is at the end by the jacks. Charging with the USB is also very easy. I have yet to run the T5 down all the way but when I get to 15 hours or so I plug it back in. The feel of the case is rock solid. I can't imagine this case giving it up even after years of use. It doesn't seem to show scratches either.
swbf2cheater
- Aug 14, 2009
I'm posting my review of the T5 sometime later today or tomorrow
