fergo
- Jan 24, 2016
Have you tried to do a factory reset and or reload the FW? I have no such issues on mine that Ive noticed.
Hi Howdy...
i did the factory reset and it worked! Thank you so much!
So as far as I understand, there is no one working solution for fade-in/out problem during playing music? I have tried to use different SD cards, factory reset, rescanning of library... nothing works.
Stay updated on iBasso at their sponsor profile on Head-Fi.
Hi guys. I have a DX90. Any idea why the same song plays at the end of a large percentage of albums? I use the "directory" "sd card" "path to browse files. I tried to delete it and I kind of did. However it now shows up but plays nothing. Drains my battery because it is still sitting there on that one song. Will I have to erase and reformat? That would be a bit of a drag.
Edit. Simply changing the name somehow unlocked the file. Deleted!
Edit. It has showed up again and drained the battery. It will do that if I don't remember to turn off the device. Just sits in the "deleted" track and plays no sound.
Have you tried the batch tool? There is a link to it on the DX80 impressions thread on the 1st page. The instructions for use with a PC are also in the download. The BT wipes the internal memory and does a clean install. The BT should clear up this problem.
With both - dx90 and dx80 - batch tools it shows me "check chip fail". Strange...
Tried different usb cables - no effect.
Now I can't start my DX90 at all. Power button doesn't work. Black screen...)))
Works with 2.0.5. And only with 2.0.5. If there any chance to use this tool for modified FW+rockbox?
I have not seen that before. Can you uninstall the BT and do a reinstall or install it on another computer? I would download the BT again.
I had the same problem, use 2.0.5 with BT and from there update without BT with your desired FW version.Just did it. On my PC and laptop. I can install only 2.0.5 over BT. All the FWs show me "Check Chip Fail".
I wouldn't know, don't use the DX90 anymore as I have a DP-X1 now. Best choice I have takenDo you have fade-out/in issue?
