iBasso DX90 Bug Thread - Post Any Firmware Bugs/Issues Here
post-11877193
Post #706 of 857
GGZZ
If you use the batch tool you don't need the screen of the DX90 as it is all done on the computer. You can also install the FW by a micro card by shutting down the DX90 and pushing the power button and the volume + button at the same time. There is a menu there that you navigate. I use the batch tool though if needed.
Jamato8 & Haens,
Really appreciate your kind help! I could not use the batch tool as the volume up and connecting to computer did not recognize the DX90 on the computer. I have tried the power button + volume up button and rebooted the DX90 and now working perfectly! Thanks again! you guys are great :)
post-11890353
Post #707 of 857
Koshiro04
Does anyone experience buggy battery level indicator? It drains so fast, but at the same time, when no bars are left on the indicator, it still plays for 1 to 2 hours. I'm on Lurker 2.3.0 and using an original Samsung S3 Battery
post-11890593
Post #708 of 857
wolfen68
Yes....same here.
post-11890791
Post #709 of 857
Watagump
Twizzler King
Orange County CA
Orange County CA
I am glad you posted this. I didnt know how long it kept playing when it had zero bars showing on the indicator. I kinda had a feeling the indicator was off.
post-11892637
Post #710 of 857
UNOE
Orange County, CA
Orange County, CA
Not really a bug but 2.3.0 makes a iPhone blue screen when using the DX90 as the iPhone external DAC.  The DX90 actually will play music through various apps for 1 to 5 seconds.  Then phone will blue screen.  Sound good too.
Wish this could be fixed.
post-11894011
Post #711 of 857
howdy
Minnesota
Minnesota
It has been doing that on other iterations as well. Mine usually will last about an hour after the indicator has disappeared.
post-11894058
Post #712 of 857
Koshiro04
Hope this will be fixed. @Paul-iBasso, hope the FW team can fix this. Cause, TBH, it is frustrating :)
post-11894145
Post #713 of 857
Watagump
Twizzler King
Orange County CA
Orange County CA
The battery bug is very annoying, how are we suppose to know we have an hour or two left when we have no clue how long the indicator has been showing zero?
post-11919097
Post #714 of 857
Anu kharmate
I using dx90 with v2.2.0.I read v2.3.0 have lot of bugs.is there are any other firmware better then v2.2.0 and not having any bugs.(I never updated any firmware before)
post-11919138
Post #715 of 857
lian00
As you can revert to previous firmware very easily, I suggest you to test the 2.30. I have no bug for myself with these two firmwares - or I did not noticed them.
post-12003002
Post #716 of 857
HiFiChris
@Paul - iBasso
It would be nice if the charging icon bug (when the DAP is turned off and plugged in for charging, the charging icon doesn't show up anymore when shortly pressing the power on/off button) that came with the latest FW could be fixed.
post-12076164
Post #717 of 857
Guppy_
Portland, OR
Portland, OR
hmmm on the song skipping a few seconds, I just briefly remembered, that my old galaxy s4 had that same issue, then a friends lg g2, a galaxy trend duos... After I gave up on google search, i remember it had something to do with either how jelly bean managed the new loading of a song, kit kat sorta fixed it IIRC
post-12137938
Post #718 of 857
DMB197641
The Netherlands
The Netherlands
Age
43
I recently got a DX90, very satisfied so far.
I tried different firmwares, one things keeps annoying me a little, sorry if this is a known bug or mentioned before:
When selecting a song or a menu option, sometimes that song/option stays highlighted and I have to press it one more time
to activate that song/option (or perhaps wait for quite a long time?!).
Any ideas/suggestions?
post-12138183
Post #719 of 857
wolfen68
Try selecting that song with a press just a second longer then you have been.  On mine once it is highlighted in this fashion it will always play if you leave it be....though it may take a few seconds to hear the song start.  I think this delay may be affected by how many tracks you have on your unit but that's only a guess.
post-12272021
Post #720 of 857
nvdprasad007
just 1hour back I installed v 2.4.0.
Before that I was installed and tried all firmwares and sticked to V2.1.0 which was suited to taste (interms of soundstage and bass).
But after listening to v2.4.0 below were my observations
1)best sound-stage ever before (able to listen more details for the same songs I was listened on other firmwares).
2)better bass when compared to other firmwares
Bug:
When trying to increase/decrease volume its getting low than the current when volume screen is active, after changing while switching back to default screen from volume level screen, its increasing 3 to 4 steps volume.
Please post your observations also.
