Lurker0
^But what if you swap cards, just for test?
Still fighting the cut out bug on my son's DX90. Mine has never done it with the exact same files/tagging. On his, it happens several times each hour. Yesterday I reformatted the card with the sd.org official formatting tool (EXFAT) and then reloaded all of the songs....and it still happens.
No firmwares have helped. My last idea is the fact that he has a 64 gb Sandisk Ultra while I have a 64 gb Sandisk Extreme....with mine being speed rated slightly faster. I still wonder if this is the difference but have not wanted to spend the money on a new card.
Per Lurker0, why not just swap cards and see how it goes?
We continue to work on this.
I will report this to our SW team. Does it work for you with less songs?
Less songs also reboot
wolfen68,
I was experiencing the cutout/dropout/whatever you want to call it with my 64GB Ultra SanDisk card and like you have commented - it was random when it would occur and appeared to be getting worse with time. So after increasing levels of frustration with multiple reformats of varying block sizes, reloads of music, reloads of firmware, etc, etc I finally switched back to a 32GB SanDisk card and low and behold have not had a single issue since. I also ran the H2testw utility and while there were no issues found I seem to recall the read/write speeds being around 15 MB/sec which is well below their advertised "up to 48 MB/sec" rate. Don't know if that had anything to do with it but I could imagine that a low or slow read/write speed might cause problems if it results in data gaps feeding the CPU and DACs - just a guess though.
I also contacted SanDisk about the issue and obtained an RMA - they replaced the card with a 64GB Extreme but I have not tried the new one out yet.
Comments?
Cheers,
Tim
Stay updated on iBasso at their sponsor profile on Head-Fi.
wolfen68,
Comments?
Cheers,
Tim
wolfen68,
See the post right above your last one - so far I have 2 1/2 hours of listening on the new card with no issues. Will report again after another 5 - 10 hours on the new card.
Cheers,
Tim
Hi
Anyone has problems with keeping their Cards in the slot? I am having trouble with keeping the memory cards in the slot. There is not click to secure the card in the slot!!
What shall I do?
Appreciate any guidance thanks
