Already fully discharged 3 times. Going for 4th…You need battery calibration, and that cat is trolling you
Haha yes that damn cat
Mystery solving... Check if it warm. If so,I checked that the 3Max was fully charged in the morning, unplugged, SHUTDOWN, went to the office.
This is what I see when I switched it back on..
I have the same issue but for my Dac battery.
Congratulations ExpatinJapan! Would you like to advise of your unique model number to join the owners list?Oopsie
Posted my arrival photo in the DX300 thread by mistake earlier today
No, it is not. It is not fully functional even on DX300 and DSD is not working. Up to PCM384 works fine directly but not 768 and no DSD. This is rather a UAPP issue.I don't know if it's possible to find some Dx300max somewhere and if the platinium version will be available or but just in case, i have a few questions:
1) Is UAPP fully functional with DSD and Qobuz in Hires ?
I don't know that one.2) is Neutron fully functional as dlna renderer, upnp access and not limited to 16b/44khz ?
What you bought is available through Google Play Store.3) as I bought both app (UAPP/Neutron) through the official Play Store, do I have to buy again those APP as apk for the DX300 and install through APK pure ?
LDAC should be available.4) is really Bluetooth DAC mode limited to AAC and SBC ? no LDAC ?
No, it is not. And not for most (99%) of the DAPs out there. PEQ runs on the CPU (SoC) and in DAC mode, USB audio data is directly (over the FPGA) fed to the DAC without any SoC intervention. This is more of an HW design issue rather than software.5) is the PEQ compatible with Bluetooth DAC and USB-C DAC ?
Yes, I was able to access my 4TB SSD disk.6) is USB-C OTG compatible with an external SSD or even a second microSD Card Reader like any android 9 smartphone ?
best regards
Thank you very muchNo, it is not. It is not fully functional even on DX300 and DSD is not working. Up to PCM384 works fine directly but not 768 and no DSD. This is rather a UAPP issue.
DX300 MAX: Edition Number details updated. Please chime in with your Edition number and I will add you to the listing (if you wish to join).
Auricon: 401
bluestorm1992:
cradon: 427
DarginMahkum: 400
Dennis80: 147
Damz87: 391
ExpatinJapan:
frankyan88: 489
fuhransahis:
Giraku:
greygrey:
hssong85:
infinatejustice:
Infoseeker:
justanut:
Libr4: 297
linnsondek: 478
mt-hifidelity:
namawee: 164
ojisan:
RPKwan: 113 HK
roygbiv6:
snapandslide: 474
stersa:
TheHelper1964:
Twister6: Demo
Tomz1313: 225
veezhun:
vkenz: 362
Yannis:
zen87192: 330
Yes, you just install the Google Play Store through APKPure and it works.Thank you very much
Do you mean Play store is available for Dx300 and Dx300max ?
I was able to access my UPnP server and play HiRes music without any issues using UAPP but MAX is just not officially supported and what would work is only PCM upto 384 kHz.So if UAPP is not fully functional, how can you reach an upnp server with a Dx300 or Dx300Max ? any idea or there is no way ?
You are right. I just tried and I don't see the LDAC option on my mobile phone.On the Dx300max manual, it seems LDAC is not available through Bluetooth DAC function. Is it same limitation with DX300 ?
Yes, but they have a highly specialised HW, as they also do some other DSP processing, without Android etc., with a much simpler controller. If the FPGA acting as arbiter would have enough gates / capacity to implement some PEQ (meaning a more powerful FPGA), the current arhitecture of the latest DAPs with FPGA would allow that, but I don't think it is enough or foreseen.I just had a little hope concerning PEQ through USB DAC or BT DAC (Sony WM1A managed to keep GEQ and all DSP features totally functional in both DAC mode and LDAC transfer)
Yep.It's a good news SSD can be accessed through USB-C connector.
FiiO _kind of_ promised implementing a system level PEQ for M17 but again I wouldn't be hopeful for a BT/DAC active PEQ.I think, as I rarely use micro SD Cards at home or office, that without any access to my personal Upnp server, it will be a no-go for any ibasso DAP (like A&K for me), I definitely need Qobuz and Synology media server access and with a PEQ available on the path (either via source or via the dap itself).
What a challenge to find a powerful DAP with complete streaming features.. It makes me something like hopeless !!! I can't imagine such big deal for such common features in 2021.
As I understand, both FiiO and iBasso uses "GW1NZ Ultra Low Power" as their FPGA and it is not a DSP FPGA, so unfortunately, HW PEQ is highly unlikely:Yes, as with my Fiio M11 I get all streaming features, I have to hope M17 will be powerful enough and can do the same as M11 and maybe make some HW PEQ applicable to the official Qobuz software too (for recording my playlists on the SDcard that UAPP can't do).
