snapandslide
Ultimate feels as if a veil has been removed, that's the easiest way for me to describe the difference.Tell me more about these differences !! Don’t have the 3Max, so I need as much info as I can to quench my thirst
Haha, finally I am not crazy after all! Agree with @snapandslide about Ultimate mode adding more clarity and energy.Only 50 odd hours burn in, but I feel 70/100 is too low - I'm comfortable at around 80, but would love to hit 70 and give myself more volume headroom. Ultimate however is a big difference in sound, it probably should remain on.
Sound wise, I'm leaning to @tawmizzzz that the lower treble is a bit hot - I'm hoping that does smooth out because otherwise I find the sound utterly brilliant and engaging.
Sixteen Men and especially "Then" are quite good recordings, which I use for testing if I like a setup. It is so sad that the guy died nearly penniless. Then there is Aydin Esen, the Holdsworth on keys. He is kind of an introvert, plays mostly just live, teaches and otherwise non - traceable. I know from an interview that he doesn't want the "music industry" breathing on his neck, so stays mostly out of sight.
Yeah just got rid of mine too! i can't get past the almost 2lb. Weight either and r2r is definitely my prefer signature from now on. GLWS.If anyone missed out on a 3Max and wants mine shoot me a PM, figured I’d post here first before it hits classifieds. As amazing as the sound is I can’t get used to the form factor anymore. I definitely prefer the r2r sound too.
thanks
It exists… it’s called Sony DMP-Z1If I could make the perfect DAP, it would be:
MAX's staging + MAX's bass + SP2000's mids + hybrid of SP2000 + MAX treble + R2R effortless portrayal + LP6's black background.
Wow Z1 is pretty ancient and still performing at this level? Amazing!It exists… it’s called Sony DMP-Z1
Haha, I was being a little sarcastic, but in all seriousness DMP-Z1 still stands as the best sound quality to my ears out of the DAPs that I’ve heard. Although I don’t know if its even considered a DAP given how huge it is.Wow Z1 is pretty ancient and still performing at this level? Amazing!
IEM: Traillii w/ stock cableJust a suggestion, when you post about hearing brighter treble, can you please also mention which iems or headphones you are using, gain setting, ultimate on/off, volume setting (digital/analog), and relative to what other source (dap) you are comparing it to? Otherwise, just saying "treble is bright" is not very helpful.
Traillii, low gain, ultimate ON, 85 digital, d3 sound setting. Comparing to W2/1A where I don't have the same pain from the lower treble area (well becomes only a cursory issue on some tracks).Just a suggestion, when you post about hearing brighter treble, can you please also mention which iems or headphones you are using, gain setting, ultimate on/off, volume setting (digital/analog), and relative to what other source (dap) you are comparing it to? Otherwise, just saying "treble is bright" is not very helpful.
The DX300MAX is a transportable not a portable so I don't see an issue with the weight and from my experience, unless you have 200 hours or more on a device, you haven't totally heard it.
The N6ii R2R is oversampling, and oversampling actually means delta sigma modulations . Despite the N6R using Discrete Resistors ladder. Not all R2R is going to be NOS and not all DAC is going to be Oversampling though. For example, both AK4499EQ can take in external digital filters and interpolations done externally. That means even on AK4499EQ, the SOC and even if the FPGA, both can do the DSP externally if implemented and neededThe 3Max is the best sounding non r2r device I have heard. Burn in will not change the more “digital” presentation of the delta sigma dac chips. The r2r from the Ti sounds much more real to my ears. “Uncolored” if you will. But yeah, I’m not selling it because of sound quality. I thought I’d be able to adjust again to the size like how I was fine with it on the 2Max, but evidently I cannot.
