Firmware 2.1.94
Factory reset has been done after firmware upgrade.
Some suggestions/issues:
(i'm an android app developer, i you need any help for you app i can help you for free)
(sorry from my english, i'm from Italy)
* USB Dac mode doesn't work: the sound is completely distorted when i try to play music from my computer.
* When i play music on a Bluetooth device, only 44khz files are working. when i try to play a file with a higher rate the app is stopping playback or is going forward a few seconds in the song randomly
* Volume adjustment via the wheel is too slow (a lot too slow), to solve this you could:
- Make the wheel sensitivity higher
- Make the wheel change sound more rapidly when turned rapidly (it's easy to do, all you have to do is check the wheel speed and increase the volume change when turning above a determined speed)
- ideally let's set the sensitivity in settings
- add a volume slider on the player main screen to allow quick and easy change
* the "volume animation" is blocking all the player view: it should be possible to make it disappear sooner or disable it (seeing the volume in the app bar is enough for me and it doesn't block access to the app)
* When a song is playing and we click on the add to playlist button, it should be possible to click on a "Add to new list" button. It's too long to have to swipe right, navigate to the playlist management tab and create a new list from there.
* all the playlists the current song belong to should be highlighted or ticked
* It should be possible to add the song to many lists at once: you could do this by using long click: when the user long click on a playlist, the app enters in multi selection mode and you can click on more playlists
* In the playlist management tab:
- The "add new list" should be on top (once you have many list it's very long to go to the end of the list) or you could add a floating button
- When you try to add a new list, if you don't click exactly on the "Playlist Name" text but on the dialog background it closes the dialog
- When you don't enter a description, the playlist list shows "null" instead of blank text
* We should be able to display song name/artist/album just above the time seek line.
* I think rows height in all the app lists should be smaller (could be a setting), browsing songs, albums, playlists... would be a lot faster
* Adding a notation feature is missing, being able to set a notation from 0 to 5 stars is very important to be able to quickly mark songs we want to hear back later or not.
* You should add a search feature
* Is it possible to disable Digital filter ? if i'm not wrong we can only choose between the 7 filters but we can't disable them completely
* it would be nice to have a landscape view with the songs list on the left and current play info on the right
* When playing a song we should be able to "show album" of "show albums of artist"
* locked screen widget should be bigger and have music control buttons
* setting lock screen to none doesn't work
* you should let the user set the screen timout time and allow to make it stay on and add an option that let screen on if the player is connected to charger
* it should be possible to save to eq user presets and ideally have separated left/right eq
* a great feature you could add that would make your device unique: a calibration feature. Here is how to can make this very easily:
play a tone at each eq band starting a very low volume until the user hear the tone.
Once it's done you know the user sensitivity differences for all frequencies and compensate them with the eq.
You can let the user save the profile for him and for each headphone he is using.
(i can make this for you if you want, i would send you the code to add to your app)
This is all for now
