chaotic_angel
Any user using it for spotify, hows the offline play?
Any chance to implement volume leveling?
As every song volume is varies quite troublesome to keep adjusting volume.
Try using Neutron Player, it has a normalization process as well as replay gain setting that kees all the levels constant.Any chance to implement volume leveling?
Two questions on this DAP. Does it have USB out? Seems like many dacamps (chord mojo, new ifi iDXD for example) don't have analog in. Second question, does it play DSD .ISO files? Thanks.
Instructions don't say anything about USB out anywhere I've found, and I haven't tried it. But there is a digital out 3.5mm port that doubles as either mini digital coax, or mini digital optical.
I have not been able to use USB out on the DX150 or the DX200. They lock up every time I try. I have a Teac UD-503 Heaphone Amplifier and have been trying to use USB out to no avail. Optical only works with the DX200, the DX150 locks up. Funny my AK300 has no problem, nor does my DP-X1 or FiiO X7MkII, they all do USB out. I have Lurkers FW on DX200 and sometimes it will work but studders so I just stop it.Two questions on this DAP. Does it have USB out? Seems like many dacamps (chord mojo, new ifi iDXD for example) don't have analog in. Second question, does it play DSD .ISO files? Thanks.
Are you looking for any particular feature like dual sd slots or optical out?Thanks a lot. Somewhere there was a list of DAPs that work as transports but I think all of them are out of my price range.
I can think of the Xduoo X10T and the Cayin N3 which both work fine as transports.
