turokrocks
- Sep 23, 2011
its a real downer when you get bored with your audio tracks, I guess thats why you madmen (and girls) keep buying bigger and better, just so you can listen to the same music with new enthusiasm![]()
Strange but it seems you can put the DX100 in a state of sleep while attempting to shut it down. Basically when the DX100 asks you if you want to shut down you have the OK and Cancel buttons. Press ok once and then it will give you another prompt to shut it down. This time just press the side button to shut off the screen and it seems the DX100 will use minimal power in this state.
Help Please!!
Got my DX-100 today![]()
Loaded several hi-res albums, which I downloaded from HDTrack.com (the complete folders, just as they were downloaded, FLAC format)
All I see in theDX-100 are files that look like 001.NUL and nothing is playing.
A quick advice or link to an 'how-to' would be greatly appreciated (note that I am an Android noobe, coming from the plug-n-play world of Apple).
Thanks in advance!
Well, you guys were correct. It was a matter of time. A lot of it.
After about 40 minutes or so the music 'showed up'.
These hi-res files are so sweet![]()
Now to figure out how to format the SD card, load some more music, burn it in and LISTEN.
More to come...
Thanks to the generosity (and trusting nature) of another local Head-fier, I've got my greedy hands on an O2 amp for the first time. You lads who've previously been talking DX vs O2, have you any tracks that you recommend to highlight the differences?![]()
Incidentally, I rarely think about sound stage when it comes to piano solos. However, this album on the DX is quite marvelous.
(Track 12 in particular))
You can almost tell which way the piano is facing as the notes leap from the strings, get a good bounce off the soundboard and head your way. Good stuff. I consider the depth of sound to be one of this player's big strengths.
