circuithero
- Mar 6, 2008
Approximately 15 hours according to iBasso.
Originally Posted by Asr /img/forum/go_quote.gif Pico: - DAC: Wolfson WM8740 - ASRC: Analog Devices AD1896 (de-clocked to 96 kHz) - USB-I2S conversion: PCM2707 (er, unadvertised) - op-amp: Analog Devices AD8397 (built-in buffer) (not as cheap as NE5532) - battery type: 8.4V Li-Ion w/ smart charging, 20 hours - voltage swing: 8V - maximum output current: 250 mA - maximum output power: 500 mW - two-board assembly - built & assembled in USA |
Originally Posted by powertoold /img/forum/go_quote.gif Anyone have this problem: Sometimes, when the D2 is charging, the red LED in the back blinks, and every time it blinks, there is an audible "click" noise with my FreQs. |
Originally Posted by souperman /img/forum/go_quote.gif Hm, I don't have that happen to mine. Weird. I guess the best way to use it is to use it straight from battery. It's the cleanest power source anyways. |
Originally Posted by powertoold /img/forum/go_quote.gif I don't think it's audible with headphones. I think the battery charging goes in stages: solid red, blinking red, then green. |
Originally Posted by souperman /img/forum/go_quote.gif Ah, I see. I used my X3i's with it no problem though. |
Originally Posted by powertoold /img/forum/go_quote.gif Does your charging red light blink (it has a subtle blink, so you have to look directly at it)? Also, I tried feeding 24bit 96khz FLACs through the USB, and it works fine. Did someone say it isn't supposed to work? |
Originally Posted by TSi /img/forum/go_quote.gif I have ran the Viper at 11'00 position for about a day using battery only, it lasts 15 hours. So basically iBasso isnt wrong about it. |
Originally Posted by powertoold /img/forum/go_quote.gif I put in AD8599 (IC2) and ADA4841 (IC7 - main opamp). They are pretty low power opamps, so I hope I'll get longer battery. I feel like I need the battery to last as long as possible since they don't warranty the battery, heh. |
Originally Posted by souperman /img/forum/go_quote.gif Sounds like enough for me. With opamp rolling though, it may be less or more depending on the opamps you roll in. |
Originally Posted by powertoold /img/forum/go_quote.gif I haven't really experimented, but I do like the stock opamps. I tried the LT1469 for about 5 minutes but felt it was muddier than the 1364. I don't think I've lost much from the stock to ADA4841 switch (I don't feel like it's any worse), but I'm not listening analytically. I think it's a good idea to use a low noise opamp with IEMs. With the 4841, I can barely hear any hiss with my sensitive FreQs. Also, the low and high gain seem to have the same amount of hiss when I made the switch. Now, I am always using high gain because it sounds better for some reason (like more authoritative?). My Opamp supply is as follows: LT1057 LT1364 LT1469 LT6241 LT6234 LMH6643 AD8397 AD8599 AD8656 AD4841 LM4562 OPA2111KP |
