iBasso D2-Viper (Pictures, Impressions, and Reviews): Read the Rules!
Mar 6, 2008 at 11:43 PM Post #46 of 615
Originally Posted by crewchief /img/forum/go_quote.gif
I know we are trying to not ask comparison questions with other amps, but I want an impression with a K701. If someone has tried yet or do you think it has enough current to drive them decently? If you guys think it would do rather OK then I want to order one, if not I will continue my search.
Personally I think driving K701's with a portable is a joke. You'll be able to play your music at ear-blasting levels, but without the finesse that a semi-good desktop amp would give you.
Mar 6, 2008 at 11:47 PM Post #47 of 615
Originally Posted by meusickfrek /img/forum/go_quote.gif
Got my viper, it came at 1230pm, stuff usually comes around 6-7 pm? anyway I think it sound great! out of box, I'll wait for some burn in for real impressions. OK one problem, Kind of a big one, I have an old beater laptop, Compaq Evo N610c by bro gave me, when I use the USB it clips, I used a newer Toshiba and everything was fine. I tried, was using WMP and then tries iTunes and it seemed to fix it but then it started again, I used MediaMonkey, itunes, WMP, and QuickPlayer from cd and from the C: drive, still the same, any suggestions OTHER THEN BUY A NEW COMPUTER? I know it's a piece, that's why I got a DAC w/my Viper.
anyone know if upgrading RAM or Music player will help this situation? I'm running Windows 2003 Pro and a Pentium 4
Mar 6, 2008 at 11:55 PM Post #49 of 615
It could be a number of reasons. It could be that the bus itself has problems.
Mar 6, 2008 at 11:59 PM Post #50 of 615
Thanks, I will try something later, I'm turning in thesis tomorrow and a little worried about messing with the computer right now. I think the Viper has great clarity but does lack some bass with the hd580's. With the Atrios the bass thumps which they did not do straight from the iA7 so I know the bass is there, burning in now.
Mar 7, 2008 at 12:16 AM Post #51 of 615
Like I said, the HD580's aren't supposed to give you bass thump
Mar 7, 2008 at 12:16 AM Post #52 of 615
Originally Posted by powertoold /img/forum/go_quote.gif
No, the charging cannot be done over USB. The charging circuit is 12V and USB only provides 5.5V.
There is no word on how long the battery lasts yet.
The paper it comes with says it should last about 15 hours per charge.
Here's some pics of mines
The led at night
Finally, my setup
Mar 7, 2008 at 12:22 AM Post #54 of 615
What can't you guys open up?
Mar 7, 2008 at 12:46 AM Post #58 of 615
jam shoot me a PM if you can help, but I stated in the earlier posts that only one of my screws comes out with a 1/16 hex bit on my screw driver. The other ones just allow my bit to rotate in them freely as if they were circular. The 5/64 hex bit is too large for them. I really want to open this baby up to see what's inside, but I can't
Mar 7, 2008 at 12:50 AM Post #59 of 615
Might be metric.
Mar 7, 2008 at 12:52 AM Post #60 of 615
Yes, as suggested above, a trip to the hardware store may be in order as it might be in metric. Metrics are available so. . . Maybe they should include one with the unit since it does come with dips.
